Latest: S2cgm
Overall: 17178
Online Now [121]:
Visitors: 119
Bots: 2
Today: 4434
Total: 136649782
Forums › The Car › 206 Talk › XSI rear axle
XSI rear axle
PostPosted: Tue Feb 22, 2011 12:34 pm Up
Brother is trying to locate a rear axle to get his xsi back on the road for when he takes his test, has bought a few in the past but each time abs light and handbrake light always stays on, anyone know why this is and does it have to be from another xsi of the same year?
PostPosted: Tue Feb 22, 2011 12:36 pm Up
What year car does he have? Maybe it's not a problem with the hubs. The problem could be elsewhere on the car.
PostPosted: Tue Feb 22, 2011 12:42 pm Up
Its a 2001 model and apparently the garage has tried everything they could think of to solve the issue but still there
PostPosted: Tue Feb 22, 2011 12:48 pm Up
If its non-plexed you need a non-plexed axle, ifs its plexed you need plexed.
If they ran a diag test, they could have seen the fault after they installed it
PostPosted: Tue Feb 22, 2011 12:51 pm Up
Can earlier hubs not be fitted?
PostPosted: Tue Feb 22, 2011 1:06 pm Up
Not sure Ed, guessing they might work
Jaffamoments
PostPosted: Fri Sep 16, 2011 8:45 am Up
Sorry to jump onto this but I'm facing having to get a rear axle for my xsi....any ideas of decent places to get one? I believe the xsi's and gti's have a different axle to a standard 206
Ashley's Firedance
i1229.photobucket.com/...s/car2.jpg
PostPosted: Fri Sep 16, 2011 8:47 am Up
eBay usually
They all are the same basically except GTi180 and SW as they have trailing arms
Then you either get disc or drum
If you have ABS, you need one from your matching electrical system
Jaffamoments
PostPosted: Fri Sep 16, 2011 8:49 am Up
Disc on mine. Dont think I have ABS (typical female response!)
Ashley's Firedance
PostPosted: Fri Sep 16, 2011 8:52 am Up
ABS is standard equipment on an XSI Wink
Look for the little yellow warning light on the instrument cluster when you start up.
Either a picture of a car skidding OR it will say ABS
Open the bonnet, look near the passengers front light....do you have a square-ish thing with some pipes coming from it?
PostPosted: Fri Sep 16, 2011 8:54 am Up
Didn't think you could get a non-plexed XSI?
Her's is a Y-reg
PostPosted: Fri Sep 16, 2011 9:03 am Up
Her's is a Y-reg
You can get a non plexed XSI but there very rare as they where only produced for about a year before multiplexing came out Wink
PostPosted: Fri Sep 16, 2011 11:26 am Up
pics of the engine bay would help.
PostPosted: Fri Sep 16, 2011 11:33 am Up
XSI spec was launched october 2000.
So YES there are non plexed 206 XSI's out there but there pretty rare Wink
