Online Now [257]:
Visitors: 256
Today: 42768
Total: 116849656
Forums › The Car › 206 Problems › Very smokey when cold
Rob2859
PostPosted: Tue Feb 22, 2011 12:03 pm Up
As the title says. only when cold, white smoke. Engine has done less than 50k
What could it be other than piston rings and if it is piston rings how long will it last?
MutilateTheDead
PostPosted: Tue Feb 22, 2011 12:10 pm Up
That happens to mine but only when first starting and for a few miles.
206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out!
PostPosted: Tue Feb 22, 2011 12:15 pm Up
Heat and cold weather = condensation/steam
Cr4zYb0y
PostPosted: Tue Feb 22, 2011 12:26 pm Up
I thought it was obvious..
1.6 16v XSi Member #21
KILL COUNT: Twisted Evil
Pigeon IIIII
Dove I
Rat/Mouse I
Rabbit I
Hedgehog I
PostPosted: Tue Feb 22, 2011 12:27 pm Up
Obviously not Laughing
TTnTT
PostPosted: Tue Feb 22, 2011 12:28 pm Up
What He Said
DeadEyePaul
You thought wrong lol.. Sometimes the obvious is oblivious
Cr4zYb0y
PostPosted: Tue Feb 22, 2011 12:29 pm Up
Clearly..
Pigeon IIIII
Dove I
Rat/Mouse I
Rabbit I
Hedgehog I
eddrj
PostPosted: Tue Feb 22, 2011 1:03 pm Up
yeah happens to all cars when cold at first its normal.
Old car 2000/ 206 2.0 hdi.
MrrNoName
PostPosted: Tue Feb 22, 2011 1:29 pm Up
as said its totally normal during cold weather
Jay794
PostPosted: Tue Feb 22, 2011 1:38 pm Up
Mine does it all the time. But then, mine is a diesel
Rob2859
PostPosted: Tue Feb 22, 2011 7:00 pm Up
Very good. I Knew they did smoke when cold but I have plumes coming out of mine. My mate did say piston rings to be and i did start to worry
MrrNoName
PostPosted: Wed Feb 23, 2011 3:50 am Up
there is a MASSIVE difference between smoke and steam.
if there is white steam vapour coming out of the engine this is NOT piston rings haha. IF there is something wrong it will most likely be the head gasket letting coolant into the cylinder, where it is changed to steam.
as said before though in this kind of weather its normal to get quite a bit of steam out of the exhaust when you start up because of condensation due to a cold exhaust etc. if you are still getting this after a long journey once everything has warmed up then it may point to a gone head gasket. but you will see other evidence of this such as mayo on the dipstick, coolant loss, oil in the coolant, pressurised coolant etc.
when piston rings are gone they let oil into the combustion chamber. if you have bad rings (which I vry much doubt at 50k lol) the smoke will be thicker, and have a blueish grey tint to it. it will be constant when the engine is hot and cold. and it won’t be clear and white like steam.
if for some reason you can’t tell the difference between smoke and steam just put your hand close to the exhaust for a few seconds when the cars running. if you hand gets wet. its steam.
sounds like your mate doesnt know what hes on about to be fair Razz its pretty noobish to assume a car has bad piston rings because it steams when cold Laughing
Kersh
PostPosted: Wed Feb 23, 2011 3:55 am Up
if you put your foot down and you cant see the milkman climbing in through the bathroom window then you have a smoke problem
Member number: 36
