Posted: Sun Feb 20, 2011 5:19 pm |
Hi all sorry for my first post to be a problem, but I was wondering if anyone else knew anything about this fault, really worried that it's going to cost me a fortune: -
In 4th or 5th if I press the accelerator about 3 1/4s down or more and hold it there to get from 60 to 70 mph for example it will sometimes jump in rpms and give no extra power as if I have pressed the clutch.
It seems to happen at about 3k rpm and jump to 4 very quickly if I let off the accelerator a bit it settles again.
Many thanks in advance for any tips or info on it.
| | ![](images/spacer.gif) |
Posted: Sun Feb 20, 2011 6:50 pm |
I'd say your clutch is on its way out.
| Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi | |
Posted: Mon Feb 21, 2011 2:08 am |
Cheers for the reply, I thought it might do it pulling away too when it's the clutch. Is it usual for it to do it in the higher gears with lower torque?
Posted: Mon Feb 21, 2011 3:36 am |
mine done this specially going up hills your clutch is on its way out but tbh mine took months before it fully went will cost u about 250 in a garage to get the clutch done or u can buy a clutch kit off ebay but it is quite a big job
Posted: Mon Feb 21, 2011 5:31 am |
Cheers for both replies, I did worry that could be the case, it's booked in now for this week will post what finally happened incase it helps other people.
Posted: Wed Feb 23, 2011 5:14 am |
Well, it's in for a new clutch now, £220 including labour, parts and VAT, does that seem ok? Apparently it had already been adjusted to it's maximum.
Posted: Wed Feb 23, 2011 6:52 am |
ian_r_young wrote: |
Well, it's in for a new clutch now, £220 including labour, parts and VAT, does that seem ok? Apparently it had already been adjusted to it's maximum. |
are they using valeo clutch?
Posted: Wed Feb 23, 2011 7:01 am |
Cheers for the reply, I thought it might do it pulling away too when it's the clutch. Is it usual for it to do it in the higher gears with lower torque? |
Someone will correct me if I'm wrong; but when your clutch starts to go, it works its way down the gears.
Posted: Wed Feb 23, 2011 9:14 am |
£220 is a good price!
