Online Now [347]:
Visitors: 345
Bots: 2
Today: 29666
Total: 105293086
Forums › The Car › 206 Problems › 206 1.4 glx 50k 2001 - clutch slip in 4th and 5th
ian_r_young
PostPosted: Sun Feb 20, 2011 5:19 pm Up
Hi all sorry for my first post to be a problem, but I was wondering if anyone else knew anything about this fault, really worried that it's going to cost me a fortune: -
In 4th or 5th if I press the accelerator about 3 1/4s down or more and hold it there to get from 60 to 70 mph for example it will sometimes jump in rpms and give no extra power as if I have pressed the clutch.
It seems to happen at about 3k rpm and jump to 4 very quickly if I let off the accelerator a bit it settles again.
Many thanks in advance for any tips or info on it.
peugeot 206 1.4 glx
roberto.f
PostPosted: Sun Feb 20, 2011 6:50 pm Up
I'd say your clutch is on its way out.
Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi
ian_r_young
PostPosted: Mon Feb 21, 2011 2:08 am Up
Cheers for the reply, I thought it might do it pulling away too when it's the clutch. Is it usual for it to do it in the higher gears with lower torque?
peugeot 206 1.4 glx
benb
PostPosted: Mon Feb 21, 2011 3:36 am Up
mine done this specially going up hills your clutch is on its way out but tbh mine took months before it fully went will cost u about 250 in a garage to get the clutch done or u can buy a clutch kit off ebay but it is quite a big job
1.1lx 2000 plate
ian_r_young
PostPosted: Mon Feb 21, 2011 5:31 am Up
Cheers for both replies, I did worry that could be the case, it's booked in now for this week will post what finally happened incase it helps other people.
peugeot 206 1.4 glx
ian_r_young
PostPosted: Wed Feb 23, 2011 5:14 am Up
Well, it's in for a new clutch now, £220 including labour, parts and VAT, does that seem ok? Apparently it had already been adjusted to it's maximum.
peugeot 206 1.4 glx
PostPosted: Wed Feb 23, 2011 6:52 am Up
are they using valeo clutch?
roberto.f
PostPosted: Wed Feb 23, 2011 7:01 am Up
Someone will correct me if I'm wrong; but when your clutch starts to go, it works its way down the gears.
dturbopeck
PostPosted: Wed Feb 23, 2011 9:14 am Up
£220 is a good price!
