Latest: cogeim7
Overall: 17185
Online Now [672]:
Visitors: 672
Today: 150192
Total: 147442473
Forums › The Car › 206 Problems › Heater not working
Heater not working
gavlar83
PostPosted: Sat Feb 26, 2011 4:57 am Up
hi,i recently fitted my standard sterero back in my 206 and since i re installed it my heater has stopped working,any ideas what it cud b?thanks
is learning slowly but surely Smile
Signature Removed - Please See Your PM's
stevedude
PostPosted: Sat Feb 26, 2011 5:44 am Up
when you say not working, ya mean only cold air comes out, or no fan action at all
Happydays
Ben750
PostPosted: Sat Feb 26, 2011 5:49 am Up
If it happened straight after fitting the stereo, I would guess you've disturbed some wiring in the dash.
gavlar83
PostPosted: Sat Feb 26, 2011 9:07 am Up
hi,not working at all not even cold air
PostPosted: Sat Feb 26, 2011 9:16 am Up
Either:
You have knocked a wire when refitting the stereo ( very possible seeing where the blower lives )
Blown a fuse in either of the fuse boxe's ( there's 2, BSI in the cabin & the BM34 under the bonnet )
The blower motor has died
You damaged the BSI in someone / crashed part of the software / corrupted the configuration.
Remember it's a 206, the blower motor only works with the engine running Wink
Rob2859
PostPosted: Sat Feb 26, 2011 9:38 am Up
MrBSI wrote:
Either:
Remember it's a 206, the blower motor only works with the engine running :wink:
very annoying. How hard would it be to change this?
Also there is a big plug under the glove box. try that mine has a bad connection and stops the heater from working.
PostPosted: Sat Feb 26, 2011 9:47 am Up
PSA Peugeot / Citroen did this for a reason.
It drains the battery.
If the engine isnt running then no heat is being produced to heat the cabin.
On the older PSA stuff with the first generation climate control systems it was bloody annoying having the blower motor suddenly burst in to full speed as soon as the ignition was turned on, it really p**sed me off when I had the 406 Twisted Evil
There is NO point having a heater blower motor running unless the engine is.
gavlar83
PostPosted: Sat Feb 26, 2011 12:03 pm Up
does anyone no or have a fuse box diagram telling you what the difrent fuses do and where they go and what amp they should b thanks
Rob2859
PostPosted: Sat Feb 26, 2011 12:07 pm Up
Well there is. Its only spinning a fan so i doubt it uses that much power. The water in the heater matrix is still hot for quite some time after the engine is off; the heater would still work for a fair while before it went cold like it does in many other cars.
Ash
PostPosted: Sat Feb 26, 2011 12:14 pm Up
I agree. For example, cars warmed up. You stop and turn off the engine. Windows steam up, instead of starting the car, you just use the motor. Simples.
PostPosted: Sat Feb 26, 2011 12:18 pm Up
RTFM Wink
public.servicebox.peug..._en_us.htm
PostPosted: Sat Feb 26, 2011 12:19 pm Up
If you want heat then leave the engine running Rolling Eyes
Simples Wink
Mike
PostPosted: Sat Feb 26, 2011 12:20 pm Up
Trade Rating: +28
Is this not the stage where you get out the car? Wink
gavlar83
PostPosted: Sat Feb 26, 2011 1:13 pm Up
Simples Wink
i dont think leaving the engine running if we have anymore ice in the mornings b4 work.an the windows steam up without the blower
Ash
PostPosted: Sat Feb 26, 2011 2:19 pm Up
Naa, she didn't want too.
