Online Now [70]:
Visitors: 69
Today: 87383
Total: 117550849
Forums › Tuning, Modification & Legal › Project Cars › 206 GTI 180 Rally car project
Go to page Previous  1, 2, 3 ... 7, 8, 9 ... 11, 12, 13  Next
imjeeves
PostPosted: Sun Feb 27, 2011 6:21 pm Up
macj
PostPosted: Mon Feb 28, 2011 12:02 pm Up
Thats a cracking job mate..... nice to see it coming together now.
PostPosted: Mon Feb 28, 2011 1:15 pm Up
I've seen nicer looking wheels!
imjeeves
PostPosted: Mon Feb 28, 2011 1:21 pm Up
True about the wheels but the grow on you. Plus they are the best in the Market and they sponsor me and they were free Smile
PostPosted: Mon Feb 28, 2011 1:28 pm Up
So what radiator are you using? Standard hoses too?
imjeeves
PostPosted: Mon Feb 28, 2011 2:36 pm Up
Yes I lowered the radiator and just used the standard one. Samco hoses for the radiator
PostPosted: Mon Feb 28, 2011 3:00 pm Up
So is the radiator angled now? Or vertical still? We need pictures.
Schumi
PostPosted: Tue Mar 01, 2011 6:40 am Up
Is the ecu tune completed ?
2005 206 RC RED
imjeeves
PostPosted: Tue Mar 01, 2011 7:26 am Up
No not yet. I finished off all the wiring last night so tonight i should be calibrating the sensors and then i will try to start it for the first time!
Schumi
PostPosted: Tue Mar 01, 2011 11:10 am Up
Good luck. I hope you enjoy when you tuning.
2005 206 RC RED
imjeeves
PostPosted: Tue Mar 01, 2011 7:57 pm Up
Tried to start the car tonight but with no luck. The engine turned over all ok but the ecu didnt seem to pick up the crank sensor and so the engine wasnt seen as turning over by the ecu. Therefore no spark etc.
Any of you aftermarket ecu guys had this problem?
I tired changing to another sensor but had the same problem.
PostPosted: Wed Mar 02, 2011 2:53 am Up
You using the standard crank sensor? I got some new pins for the standard plug from the Peugeot dealer and dismantled the plug to rewire the Omex directly into it.
imjeeves
PostPosted: Wed Mar 02, 2011 2:58 am Up
Yes i am using the standard sensor. I measured the resitance between the two terminals and i get a varying resistance as I put a bolt etc close to it. I get this before the plug and at the plug before the ecu. I think i will need to call Emerald this morning.
briant
PostPosted: Thu Mar 17, 2011 6:13 pm Up
Hi Mate ,could you tell me what inlet manifold you have i got the manifold for mine with the tb kit from mtech but i couldnt fit it with pas pump in place and looking at angle of tb's im not sure i can close the bonnet.I have only started to make up engine looms so will test fit the bonnet next week.
Any help would be appreciated
also have you a connection on manifold for vacuum pipe to brake servo
cheers Brian
206 Rallycar
PostPosted: Fri Mar 18, 2011 1:46 am Up
You need the MP05 manifold to clear the PAS pump.
Page 8 of 13
