Latest: sparrowdclxvi
Overall: 17139
Online Now [113]:
Visitors: 112
Today: 37931
Total: 113485959
Forums › The Car › 206 Problems › Ball joint
Ball joint
sp5flys
PostPosted: Mon Feb 28, 2011 4:45 pm Up
does anyone know how much it would cost to replace the ball joint
thank you
.. Peugeot 206 2.0 D turbo hdi ..
PostPosted: Mon Feb 28, 2011 4:53 pm Up
just the cost of a new wishbone.....
sp5flys
PostPosted: Mon Feb 28, 2011 4:55 pm Up
wishbone? how much is that Smile is it easy to do
PostPosted: Mon Feb 28, 2011 4:59 pm Up
depends on what brand you go for.
genius peugeot stuff cost around 100 each. cheap ebay stuff probably 30-ish each.
last time macj change mine in around 30mins (both side)
sp5flys
PostPosted: Mon Feb 28, 2011 5:06 pm Up
r not bad better than i through then, im pretty sure thats wot up with it, the brakes at the front seem to shake when cuming to a stop Sad
PostPosted: Mon Feb 28, 2011 5:07 pm Up
but how does that related to the ball joint? lol
Sounds like a problem with the brakes then! Like warped discs!
sp5flys
PostPosted: Mon Feb 28, 2011 5:39 pm Up
i fort the brakes r warped becoz the ball joints r loose my front wheels shake ?
M60SHW
PostPosted: Mon Feb 28, 2011 5:42 pm Up
unbalanced wheels or warped disks Imo
Team, ST
Team, Gti 138 track slag
PostPosted: Mon Feb 28, 2011 5:45 pm Up
that can't be right.
brake disc are bolt onto the hubs, so as the calipers. ball joint wouldn't cause your disc to warp
sp5flys
PostPosted: Mon Feb 28, 2011 5:49 pm Up
wheels r ok pulls alittle to the left im come to the conclusion brakes are warped the front discs r abot 10mths old the last ones warped too does anyone think its the ball joint ?or am i wrong Smile
PostPosted: Mon Feb 28, 2011 5:59 pm Up
sticky calipers causing pad always in contact with the disc thus lead to warp disc?
sp5flys
PostPosted: Tue Mar 01, 2011 1:36 am Up
how would i sort that problem if thats the case Smile
thank you
PostPosted: Tue Mar 01, 2011 2:31 am Up
If the ball joint was that bad you'd notice looseness in the suspension or steering.
sp5flys
PostPosted: Tue Mar 01, 2011 8:07 am Up
steering is fine, im realy stuck with this i don't know what to do Sad sum1 quoted me 300 quid to chang the balljoint arms
