Posted: Mon Feb 28, 2011 4:45 pm |
does anyone know how much it would cost to replace the ball joint
thank you
| .. Peugeot 206 2.0 D turbo hdi .. | |
Posted: Mon Feb 28, 2011 4:53 pm |
just the cost of a new wishbone.....
Posted: Mon Feb 28, 2011 4:55 pm |
wishbone? how much is that is it easy to do
Posted: Mon Feb 28, 2011 4:59 pm |
depends on what brand you go for.
genius peugeot stuff cost around 100 each. cheap ebay stuff probably 30-ish each.
last time macj change mine in around 30mins (both side)
Posted: Mon Feb 28, 2011 5:06 pm |
r not bad better than i through then, im pretty sure thats wot up with it, the brakes at the front seem to shake when cuming to a stop
Posted: Mon Feb 28, 2011 5:07 pm |
but how does that related to the ball joint? lol
Sounds like a problem with the brakes then! Like warped discs!
Posted: Mon Feb 28, 2011 5:39 pm |
i fort the brakes r warped becoz the ball joints r loose my front wheels shake ?
Posted: Mon Feb 28, 2011 5:42 pm |
unbalanced wheels or warped disks Imo
| Image removed due to size
Team, ST
Team, Gti 138 track slag | |
Posted: Mon Feb 28, 2011 5:45 pm |
sp5flys wrote: |
i fort the brakes r warped becoz the ball joints r loose my front wheels shake ? |
that can't be right.
brake disc are bolt onto the hubs, so as the calipers. ball joint wouldn't cause your disc to warp
Posted: Mon Feb 28, 2011 5:49 pm |
wheels r ok pulls alittle to the left im come to the conclusion brakes are warped the front discs r abot 10mths old the last ones warped too does anyone think its the ball joint ?or am i wrong
Posted: Mon Feb 28, 2011 5:59 pm |
sticky calipers causing pad always in contact with the disc thus lead to warp disc?
Posted: Tue Mar 01, 2011 1:36 am |
how would i sort that problem if thats the case
thank you
Posted: Tue Mar 01, 2011 2:31 am |
If the ball joint was that bad you'd notice looseness in the suspension or steering.
Posted: Tue Mar 01, 2011 8:07 am |
steering is fine, im realy stuck with this i don't know what to do sum1 quoted me 300 quid to chang the balljoint arms
