Latest: ArtistKS
Overall: 17145
Online Now [63]:
Visitors: 62
Today: 10559
Total: 116025922
Forums › The Car › 206 Problems › help changing the driver side wishbone
Go to page Previous  1, 2
hebby
PostPosted: Tue Mar 01, 2011 12:19 pm Up
kit325 wrote:
Is better to have two person on this job, taking out wishbones gonna be the easy part. The hardest part going to be putting the new wishbone in, especially trying to slot in the ball joint to the hub.
Please refer to this post below,
www.206info.co.uk/Foru...hbone.html
ps: watch out your drive shalf might pop out!
Good luck!
yeah what he said ^^^^^^^
doing it on my own cost me a black eye and a kick mark on the wing when the long bar i was using slipped out and smashed me in the face HARD Mad left the car for 2 days before i decided to have another go WITHOUT THE BAR lol
All hail the mighty cable tie were would we be without them?
kit325
PostPosted: Tue Mar 01, 2011 2:31 pm Up
Sorry to hear that, better ask for help from your mates. An extra pair of hands will be handy.
kit
sean321
PostPosted: Thu Aug 30, 2012 7:07 pm Up
Drive shaft seems to have popped out whilst trying to jack the wishbone ball joint into the hub.
Any advice?
Thanks!
kit325
PostPosted: Fri Aug 31, 2012 1:38 am Up
Will be alright if is the driverside driveshaft, u just need to push it back into its original position. However will be a bit messy if your passenger side drive shaft pop out, it will be gear oil everywhere.
I just change my ball joint rubber cover 3 months ago and found out that the best way to slot in the ball joint back into the hub as following (without using the jack),
1. U need 2 person on the job.
2. u need to use a flat head screw driver to slot it into the gap on hub to widen the slot for the ball joint.
3. 1 person will need to pull down the wishbone ball joint untill it it lower enough to position it into the hub.
4. Another person will need to hold and push the hub into the subframe direction while second person position the ball joint into the hub.
5. Once the ball joint is slot into the hub, use a torch to check the hole where u suppose to put the bolt in, it should be perfect round (so the bolt will able to slot in without problem). otherwise, u need to use the flathead screwdiver to push the top of your ball joint (adjust) untill the hole is fit to slot in a bolt. This happen because most likely you will push in the ball joint too deep and if the groove on the ball joint not in the right posistion, u won't able to slot in the bolt even u hammer it.
6. Once all done, take it from a ride to check for the handling. U most likely need a wheel alignment after this.
Good Luck!
kit
sean321
PostPosted: Fri Aug 31, 2012 10:07 am Up
Thanks kit325, yes it is the drivers side.
When I turn the disc on the hub, the axle doesnt seem right and it seems something is dislocated in the CV joint.
I will try your advice and see if it pops back in.
Think I'll also try spring compressors as they are a bugger to get in.
Any special advice for getting the drive shaft back in, or just a bit of persuasion?
Page 2 of 2
