Online Now [222]:
Visitors: 221
Today: 47347
Total: 138782429
Forums › The Car › 206 Problems › Problems With Electrics :(
Lewis1304
PostPosted: Wed Mar 02, 2011 7:10 pm Up
Hello Guys,
Recently wired in a sub, dvd head unit and extra screen. Driving today, flicked my full beam on the head unit switched off :S confusing, also did the same for fog lights.
The head unit kind of reset.
Now it could be the sub drawing too much power, can I upgrade the battery?
Lewis
206 1.6 16v, Nimrods, Full SP Kit, 3 Stage Valve Cut Head, 4-1 Manifold With Decat, Pug Sport Backbox, Vibe Speakers, HIDs In Projectors, DVD screens & Sub Smile
PostPosted: Wed Mar 02, 2011 7:14 pm Up
what battery are you using?
Lewis1304
PostPosted: Wed Mar 02, 2011 7:16 pm Up
Just a standard replacement, dont know which :S What would you recommend?
Lewis
PostPosted: Wed Mar 02, 2011 7:21 pm Up
www.206info.co.uk/Foru...rt=15.html
check this maybe?
Lewis1304
PostPosted: Wed Mar 02, 2011 7:34 pm Up
Looked, Is there any cheaper battery that would stop it doing it?
Lewis
Kersh
PostPosted: Thu Mar 03, 2011 4:09 am Up
if you havent amped the sub and its too high a power for the HU then yes, it will cut out, get an amp.
Member number: 36
Lewis1304
PostPosted: Thu Mar 03, 2011 5:49 am Up
It's a active sub so ready has a an amp on it.
Lewis
Ash
PostPosted: Thu Mar 03, 2011 12:33 pm Up
Rev the engine to 3000 RPM, then do it again. See what happens.
Lewis1304
PostPosted: Fri Mar 11, 2011 5:02 am Up
Ash why rev it up to 3000 for?
PostPosted: Fri Mar 11, 2011 5:03 am Up
It'll will create more power.
Lewis1304
PostPosted: Fri Mar 11, 2011 5:19 am Up
Okay I will try this later. If it is this what does it mean?
PostPosted: Fri Mar 11, 2011 5:36 am Up
A bigger battery is required I imagine. But don't quote me on that.
Lewis1304
PostPosted: Fri Mar 11, 2011 7:30 am Up
Thats fine dude, What battery would you recommend, is it the same size wise, so it will fit in my battery box?
Lewis
Lewis1304
PostPosted: Sat Mar 12, 2011 5:24 am Up
Didn't make a difference Sad
PostPosted: Sat Mar 12, 2011 6:39 am Up
how you got it wired in?
Not piggyback wires are you?
