Latest: S2cgm
Overall: 17178
Online Now [1360]:
Visitors: 1359
Today: 72254
Total: 137341643
Forums › The Car › 206 Problems › 1.6hdi gti unblock fuel filter
Baz.mc
PostPosted: Fri Mar 04, 2011 5:08 am Up
It's flashing up that the fuel filter is blocked.. I take it the filter needs changing, where abouts is it located?? Thanks
1.6hdi gti
PostPosted: Fri Mar 04, 2011 5:23 am Up
FAPTASTIC Laughing
Why do people keep buying these pieces of s**te Rolling Eyes
PostPosted: Fri Mar 04, 2011 5:41 am Up
Use the search button at the top, these FAPTASTIC problems have been covered lots on the forum Wink
Mattie-RS
PostPosted: Fri Mar 04, 2011 5:58 am Up
MrBSI wrote:
FAPTASTIC Laughing
'because there ace Laughing
Just take the piece of s**t out Razz
Baz.mc
PostPosted: Fri Mar 04, 2011 9:00 am Up
Rite well I've searched for my faptastic problem and I can't find ote???
1.6hdi gti
PostPosted: Fri Mar 04, 2011 9:07 am Up
It's not forced to need changing, could be low on fluid or the sensors have gone.
Needs code reading first tbh.
PM a member called paulrushton, met up with him today I turned his FAP off in the BSI and then deactivated the ECU, and he's had a map wrote to over write the ECU coding to take the FAP out. And its working fine now, just needs the physical stuff removing.
Baz.mc
PostPosted: Fri Mar 04, 2011 9:41 am Up
Rite ok then so what do you think the best step for me is then?? How do I sort this fap out and how much is it gunna cost? Cheers
1.6hdi gti
PostPosted: Fri Mar 04, 2011 9:49 am Up
Not sure how much he paid for the map, but he uploaded it himself.
I deactivated it in the BSI and disabled the ECU for £20
Then you need to disconnect the sensors, and then remove the particle filter and fit a normal pipe instead.
Baz.mc
PostPosted: Fri Mar 04, 2011 9:55 am Up
If I was to just get it mapped wouldn't that work? Thanks
1.6hdi gti
PostPosted: Fri Mar 04, 2011 9:58 am Up
I'm not 100% sure, but if you are disabling it you might as well remove it and then just sell it.
