Posted: Fri Mar 04, 2011 5:12 am |
Last night driving home when i braked for roundabouts i got a warning light flash at me and a beeping like the sound when fuel is low.
Fuel level is fine.
I havent looked in the owners manual yet but the light that flashed was on the right hand side under the one which shows when you have dipped main beam on.
Any ideas??
Posted: Fri Mar 04, 2011 5:17 am |
Could be low brake fluid (caused by worn brakes usually)
Posted: Fri Mar 04, 2011 5:21 am |
| borinous wrote: |
Fuel level is fine.
Any ideas?? |
Go look in your owners manual
Posted: Fri Mar 04, 2011 5:23 am |
Pads are relatively new 1-2000 miles if that might be fluid i did think that.
I will look in the manual just aint had a chance yet
Cheers
Posted: Fri Mar 04, 2011 7:18 am |
not sure but is you car fitted with brake wear sensors??
Posted: Fri Mar 04, 2011 7:26 am |
| Golfguy206 wrote: |
| not sure but is you car fitted with brake wear sensors?? |
No 206 has brake pad wear sensors
Posted: Fri Mar 04, 2011 8:03 am |
Think it was the battery light....just went out to try the car again and it would start not even turn over checked the battery connection and the quick release one closest to the front of the car had come off!!! Think ill be changing this to a standard type connector.
