Latest: tebas93089
Overall: 17179
Online Now [121]:
Visitors: 121
Today: 37783
Total: 138456316
Forums › The Car › 206 Talk › Location of Oil sensor & earthing points in car?
myke
PostPosted: Fri Mar 04, 2011 10:40 am Up
Hi guys,
Looking to disconnect the stupid sensor that tells me the oil is overflowing when it's not... where's that located? I can only see posts about the oil pressure sensor o.O
& Also I need to earth two switches I have as they're illuminated, where's the best place to earth them to in the car? They're under the diagnostics panel, could I earth them to the ashtray light?
Cheers
Myke
PostPosted: Fri Mar 04, 2011 11:16 am Up
Earthing, you can just tap into any earth wire if you see one.
Off the top of my head, near the steering wheel, there's an earthing point near the ash tray B pillar and fuse box.
The oil sensor is near the sump I think. You could always just get it turned off in the BSI
myke
PostPosted: Fri Mar 04, 2011 12:09 pm Up
Cheers electric guru Lee Razz You're a star lol.
I don't know anyone with PP and not really wanting to spend 60 quid or whatver it is just because of a beep it gives when i switch it on Razz
Wish there was a rep system here
PostPosted: Fri Mar 04, 2011 12:10 pm Up
Where you from?
myke
PostPosted: Fri Mar 04, 2011 12:13 pm Up
Near Luton, so it's the opposite end of you Razz I've checked out your config thread before and saw how far away you are Razz
PostPosted: Fri Mar 04, 2011 12:15 pm Up
Yeah that is a bit of a trek Laughing
I might be having a drive down to the fast show [NN29 7XA] on the 26th, and if your interested I could always do it there if you met me or if you were going, then it would just be £20 including anything else you want turning on. Well thats if there is enough interest.
myke
PostPosted: Fri Mar 04, 2011 1:20 pm Up
Cheers for the offer but that's my bro's birthday Razz Well I might be going to the French Car Show this year... are you going? because I do like the idea of changing a few things on it's config if pos.
PostPosted: Fri Mar 04, 2011 1:21 pm Up
Not sure yet, have to see closer the time
