Online Now [535]:
Visitors: 535
Today: 166420
Total: 146621310
Forums › The Car › 206 Problems › mileage not working
mileage not working
Abzynthe
PostPosted: Fri Mar 04, 2011 2:13 pm Up
East Area Rep - Abzynthe
Ive played about with my fuel gauge and now thats working, but the mileage counter isnt Sad
The ribbon at the back has a crease in it but doesnt look broken.
any ideas?
Ste
PostPosted: Fri Mar 04, 2011 2:45 pm Up
Staff - Ste
The crease could be the cause tbh, there pretty brittle with age and even a crease can cause them to no longer work, can you not source a new part inc a ribbon and replace the creased one?
IIRC they're soldered onto the board, but aslong as your half decent with a solder iron it's a simple enough job Smile
Failing that, if you cant fix it get a new one and I'll have to come to a meet in Peterborough some time and solder it for you lols
The Cars:
Abzynthe
PostPosted: Fri Mar 04, 2011 2:57 pm Up
ah that dont sound too bad then, ill have to get it sorted, before June (MOT time) lol
panason1c
PostPosted: Fri Mar 04, 2011 6:20 pm Up
If its only the mileage counter (odometer) that isnt working then dont worry about fixing it for the mot as its not an mot test item.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Abzynthe
PostPosted: Tue Mar 08, 2011 1:34 pm Up
You need a mileage recorded on MOT though dont you?
Liam-HuTcH
PostPosted: Tue Mar 08, 2011 1:37 pm Up
East Area Rep - Liam-HuTcH
Thats exactly what i thought as it goes down on the doccumentation
Team: Smashed Up Firedance
Team: Black 206
davieboy86
PostPosted: Tue Mar 08, 2011 1:42 pm Up
My ribbon broke, I changed the dials over and the guy said I needed to have a milage to record so I had to put in salvaged clocks so my MOT certificate says 76 thou instead of 43. I need to find some one who could help my repair it, I can find new clocks at the scrappy all day long, just no idea how to repair it
Abzynthe
PostPosted: Tue Mar 08, 2011 1:43 pm Up
does it matter if the mileage is lower than the last recorded mileage? If not, then i can just get a crappy set to put in for the MOT, as i dont fancy re-glueing my plasma dials.
Liam-HuTcH
PostPosted: Tue Mar 08, 2011 1:45 pm Up
well mine says 30k on the mot certificates, when old ones say 80k so wouldnt of thought so
Team: Black 206
namgaj
PostPosted: Tue Mar 08, 2011 1:59 pm Up
If people want the same mileage what was on in the first place, there's plenty that do it- heres one near me-
www.mileagecorrections...ection.asp
4.0 V8 S-Type Jaguar
panason1c
PostPosted: Tue Mar 08, 2011 2:22 pm Up
Yes, its recorded on the mot certificate but it's of no concern to the mot tester, or the authorities if its the exact same mileage recorded at every mot!
BMW K1200RS
Abzynthe
PostPosted: Tue Mar 08, 2011 2:38 pm Up
hmm, might just put a post it on the cluster before the MOT then lol.
