Latest: Stu-mill
Overall: 17131
Online Now [318]:
Visitors: 318
Today: 48552
Total: 104684798
Forums › The Car › 206 Problems › over a bump or pothole, limp mode
micka
PostPosted: Sat Mar 05, 2011 3:53 am Up
I have a 206 hdi 90, when I go over a bump or pothole now and then, it goes into a kind of limp mode it feels slower, but when I press the red fuel cut off switch under the bonnet the car goes back to normal driving?
Why would it do this, is it normal?
Above the Redline !!!
qwert
PostPosted: Sat Mar 05, 2011 4:29 am Up
dont hit the pot holes or speed bumps so hard and it wouldnt do it
brum brum
MrrNoName
PostPosted: Sat Mar 05, 2011 4:38 am Up
i thought the fuel cut off switch "cut off" fuel, not put the car in and out of limp mode lol??
micka
PostPosted: Sat Mar 05, 2011 5:18 am Up
I don't just it does it now and then when I go over a little bump, some bumps it does it and some it don't.
I don't cut my car off it still drives but feels like I'm towing 2 cars behind it, like lack of performance until I press that red cut off switch, it does this itermittently
kencogurl
PostPosted: Sat Mar 05, 2011 5:25 am Up
Wales Area Rep - kencogurl
you might one chack your ABS ECU fault. it can cause te car to cut out and/or go into limp mode
micka
PostPosted: Wed Mar 09, 2011 5:51 pm Up
How would I know if I have the abs ecu fault kencogurl? Have you experienced this or know of it what does it do to cause it to go into limp mode?
Cheers
kencogurl
PostPosted: Thu Mar 10, 2011 3:02 am Up
mine was in limp mode and cut out on me 4 times while on the way to a meet in peterborough and back. the only way i found out was having someone read my ecu with peugeot planet, stuff like ABS ECU fault is realy a garages domain. don't get me rong when things go wrong with mine ill fix it myself, but that was one thing i can't fix as they say the ECU need a neuk and boot
