Latest: cogeim7
Overall: 17185
Online Now [603]:
Visitors: 601
Members: 1
Today: 99925
Total: 146998399
Forums › The Car › 206 Problems › brakes need bleeding air in brakes
20619d
PostPosted: Tue Mar 08, 2011 10:53 am Up
is it easy job? wot do i need plus how do u do it? please yep as got air in brakes
leigh_boy
PostPosted: Tue Mar 08, 2011 10:59 am Up
u need a spanner, a friend to help. also a bleed kit or a bit of pipe and a jaw of brake fluid,
then you fill up brake fluid res, leave the top off, put the pipe ./ bleed kit on the bleed nipple. and the pipe going in to a jaw of oil, ghet your friend to pump the break 3 or 4 times and hold foot down as you undo the bleed valve and look for bubble appearing in the jaw of oil. then tighten up and then your friend can release break, do this untill the break feels solid on both sides.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
MrrNoName
its a 2 person job, basically one has to undo bleed nipples at each wheel while the other pumps the pedal, once the airs out you do the nipple up whilst fluid is being pumped out to prevent air getting sucked back in
Kersh
PostPosted: Tue Mar 08, 2011 11:09 am Up
[quote="leigh_boy".. and a jaw of brake fluid, ..[/quote]
not recommended.. Smile
Member number: 36
PostPosted: Tue Mar 08, 2011 12:19 pm Up
Gunson Easibleed makes the job simple Wink
leigh_boy
PostPosted: Tue Mar 08, 2011 12:26 pm Up
nothing wrong with the way i do it Smile
*DEAD*206 Gti 138
Abzynthe
PostPosted: Tue Mar 08, 2011 12:27 pm Up
East Area Rep - Abzynthe
I can vouch for that Smile
PostPosted: Tue Mar 08, 2011 12:29 pm Up
Takes far to long & you risk ruining the master cylinder seals if the person pressing the BRAKE pedal goes full stroke Wink
Easibleed makes it a simple one person operation Cool
MrrNoName
PostPosted: Tue Mar 08, 2011 1:18 pm Up
just out of interest, how does it work?
Abzynthe
PostPosted: Tue Mar 08, 2011 1:27 pm Up
Basically you fill the reservior and the bottle with brake fluid, then one pipe goes on a cap with fits on your reserviour, then another pipe fits over the bleed plug. The bleed plud one has a switch similar to what goes on your tyre to blow them up, you click that into place and it does its thing.
PostPosted: Wed Mar 09, 2011 10:38 am Up
You MUST drop the tyre pressure down to around 10 psi on the tyre suppling the easibleed with air else you can damage the seals in the master cylinder Wink
Abzynthe
PostPosted: Thu Mar 10, 2011 6:00 pm Up
oops :S
Coolspot
PostPosted: Sat Mar 26, 2011 10:10 pm Up
Does anyone know where to get replacement bleed nipples set of 4?
Also i plan on changing the brake fluid when having my axle swapped, how much fluid would i require?
Cheers
206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box,
PostPosted: Sun Mar 27, 2011 2:40 am Up
Peugeot / Citroen main dealer.
Place that overhauls brake hydraulic part's.
PostPosted: Sun Mar 27, 2011 4:12 am Up
Cheers
About £6 each from stealership (0000442813) and shouldn't need more than a 1 litre (to allow for bleeding) bottle of DOT4 fluid
