Latest: Kifi69
Overall: 17183
Online Now [393]:
Visitors: 392
Today: 45362
Total: 144192411
Forums › The Car › 206 Problems › All power gone.
All power gone.
carter2902
PostPosted: Tue Mar 08, 2011 1:16 pm Up
Right i dont know if im being dumb but ive basically rebuilt the front of my car (rad, fan bumpers blah)
i took a fuse out of the bonnet fuse box however put it back in the same place.
there's no power what so ever any more not even to do my windows up... lights on the dash are very dim.. Is it a dead battery or something worse. Tryed jump starting it this didnt work
HELP!
Abzynthe
PostPosted: Tue Mar 08, 2011 1:19 pm Up
East Area Rep - Abzynthe
does sound like a battery problem.
Do you know what the fuse was for? The one you took out?
carter2902
PostPosted: Tue Mar 08, 2011 1:23 pm Up
it was for the rad fan mate
Im not that good with cars... But i drive well Razz
check the earthing aswell
carter2902
PostPosted: Tue Mar 08, 2011 1:24 pm Up
yeah had a problem with that had to do a nip and rewire with it :S
NICKST
Have you disconnected an earth Strap any were?
carter2902
PostPosted: Tue Mar 08, 2011 1:25 pm Up
well basically the earth from my old fan needed to be cut and put onto my new one... so maybe a loose connnection?
NICKST
PostPosted: Tue Mar 08, 2011 1:33 pm Up
The earth to the fan wouldn't stop the car from starting. I mean if you have had the front in pieces have accidentally disconnected a main earth strap on the body of the car or engine/gearbox.
PostPosted: Tue Mar 08, 2011 2:15 pm Up
a quick check it you can make a temp. earthing fron the negative to the suspension top mount nuts using the jump start cable.
