Latest: cogeim7
Overall: 17185
Online Now [685]:
Visitors: 685
Today: 214755
Total: 147700226
Forums › The Car › 206 Problems › antipollution fault
antipollution fault
LilLew
PostPosted: Wed Mar 09, 2011 2:57 am Up
Hey all yet anonther problem with my gti 180 now i have a anti pollution fault
So far i have connect her up to my code reader
P0141 (Oxygen sensor)
i have change BOTH lambda sensors in the exhaust but still no change its cost me just ove £200 mark and still with no joy
Can any one give any advice
2003 Pug 206 2.0 GTI 180
kieron
PostPosted: Wed Mar 09, 2011 3:04 am Up
check the current going into the sensor i think it should be around 12-15 oms
Account suspended
NICKST
PostPosted: Wed Mar 09, 2011 3:23 am Up
www.206info.co.uk/Foru...24078.html try cleaning the map sensor it's on the second diagram bottom left sensor. My did the same replaced both oxygen sensors and still there so cleaned this and been fine since. Or may be one of the sensors you got is faulty.
LilLew
PostPosted: Wed Mar 09, 2011 3:30 am Up
ok ill give that a try what number is it on the diagram so i know it is the correct one i am looking at (Number 7)
Lewis
PostPosted: Wed Mar 09, 2011 4:27 am Up
Also try cleaning the VVT solenoid Smile pull it out spray it with carb cleaner! wack it back in... worth a try
Tivoli LX 1.1
Black GTI 180
White VXR Burg
NICKST
PostPosted: Wed Mar 09, 2011 4:47 am Up
Ye number 7 is the one you want. Wouldnt recommend taking the vvt solenoid out as there very delicate part and are the good part of £80 to replace. Plus it will have nothing to do with the anti pollution fault if that wastnt working when you did the diagnostics it would come up as timeing retarded. Leave well alone. Speaking from experience here lol.
LilLew
PostPosted: Wed Mar 09, 2011 5:59 am Up
yes i know all about the cost of vvt lol stupid thing after this i am think it could be cat or maybe a dodgey fuel filter (probaly not tho)
If it turns out to be the cat what sort of price am i looking at all i can find is ranging from £200 - £700
PostPosted: Wed Mar 09, 2011 6:09 am Up
If you have replaced the sensor then check for a short or high resistance in the wiring
Bank1 Sensor 2 is the one after the cat
