Online Now [546]:
Visitors: 545
Today: 86666
Total: 105813277
Forums › The Car › 206 Problems › car not starting, and no electronics?
austin316
PostPosted: Wed Mar 09, 2011 5:14 am Up
Hi guys, i was messing about with my rear light in my boot. I blew all the electrics in my car, and the car isnt starting, have tested fuses and some are working, some are not. when my key is in ignition, my side lights are on, even though the stick says they are turned off, and when i turn my stick, still none of my lights are coming on, its just staying on the sidelights. my wipers arent working, basically, no electrics.
any help pls?
5 door
1.1 8v
04 reg
Teebag
PostPosted: Wed Mar 09, 2011 5:16 am Up
damaged bsi i thinks.... need to get it to a pug specialist but may be very expensive it the bsi has gone.
my garage inc mod list:
- Antix
MrrNoName
PostPosted: Wed Mar 09, 2011 5:25 am Up
eek. ut oh. you say you tested all of the fuzes are some are working and some are not, how about repacing the ones are 'are not' first lol?
austin316
PostPosted: Wed Mar 09, 2011 5:26 am Up
just spoken to peugeot, they said its the thing behind the fusebox, like under the dashboard, has gone, and the part is £295, but it has to go to a peugeot specialist, because it has the immobiliser and everything in it also? so guess im looking at like £400-£500? can anyone help in any way?
5 door
1.1 8v
04 reg
MrrNoName
PostPosted: Wed Mar 09, 2011 5:28 am Up
what thing? did they not even tell you the name ? lol
Teebag
PostPosted: Wed Mar 09, 2011 5:34 am Up
thats the bsi mate. the replacement part is £300ish, then it needs recoding to the car and thats the more expensive part.
- Antix
PostPosted: Wed Mar 09, 2011 5:36 am Up
Sounds like peugeot think the BSI has gone. If you are getting a new one recoded you're looking in excess of £700.
Shouldn't mess with electrics with power on Wink
Replace all the blow fuses, if its still not working, get someone to test it with Peugeot Planet to see if its communicating. If it won't, it would be cheaper to buy a 2nd hand ECU, BSI and transponder
austin316
PostPosted: Wed Mar 09, 2011 5:45 am Up
Thanks, will give this a try
5 door
1.1 8v
04 reg
austin316
PostPosted: Wed Mar 09, 2011 5:49 am Up
if i buy the 2nd hand ECU, BSI, and transponder, as this contains the immobiliser also, how would i get the immobiliser to work with my key? is it hard to do?
5 door
1.1 8v
04 reg
Try replacing the f*cked fuses first. Smile
PostPosted: Wed Mar 09, 2011 5:52 am Up
The ecu, bsi and transponder will all contain the same code so the immobliser will work.
3 blown BSI's in a month, this forum is getting more lively Laughing
Antknee
PostPosted: Wed Mar 09, 2011 5:56 am Up
Or more people are getting their DIY on Razz
MrrNoName
PostPosted: Wed Mar 09, 2011 6:46 am Up
yeah, its always "i was just fiddeling with my [insert small menial item]"
lol
PostPosted: Wed Mar 09, 2011 9:37 am Up
Gonna be more & more of these threads now the 206 is so cheap.
They killed all the Saxo's off now the chavs are working on 206's Laughing
PostPosted: Wed Mar 09, 2011 9:39 am Up
was thinking this other day, more people joining here with neons and blue lights i have notice too Laughing
