Online Now [130]:
Visitors: 129
Today: 47960
Total: 117001930
Forums › The Car › 206 Talk › Throttle Position Sensor ( now with video of problem)
leigh_boy
PostPosted: Tue Mar 08, 2011 5:46 am Up
the fault codes i had were injector 3, since all have been changed, imobaliser fault ( dont really care about that one) and knock sensor witch has also been changed.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
Kersh
PostPosted: Tue Mar 08, 2011 5:52 am Up
leigh_boy wrote:
there is fault codes but i havent had time to clean them up and check agian recently since doing the work non of them were tps tho.
hmm i can get one here: cgi.ebay.co.uk/ws/eBay...K:MEWAX:IT for £22
lol, that is a cheap aftermarket product, doesnt even say the model that it fits, id say pretty much guaranteed to not fit, its also from germany.
servicebox tells me that the part new from peugeot is
00001628JX POTENTIOMETER 161.75 GBP
so errr yeah..
Member number: 36
Kersh
PostPosted: Tue Mar 08, 2011 5:58 am Up
although saying that they have only had one person moan about quality on the feedback..
Member number: 36
leigh_boy
PostPosted: Tue Mar 08, 2011 6:00 am Up
that number matches up with the one your saying, minus the 0000
looks the same as well
if a few more ppl can confirm it looks to be that sensor il have it off you.
cheers for your help btw
*DEAD*206 Gti 138
Kersh
PostPosted: Tue Mar 08, 2011 6:03 am Up
yeah they say it fits but will it actually lol Wink and it being a sensor you have no idea of what the quality of its internals are etc etc
but yeah just let me know if you want it im in no rush.
and no problem! this is an information exchange after all Very Happy
Member number: 36
leigh_boy
PostPosted: Wed Mar 09, 2011 2:46 am Up
Got hold of a new TPS sesnr yestaday, it didnt fix the problem and yes it was a genuine one Kersh Smile
any one got any other ideas as to what it could be?
*DEAD*206 Gti 138
Kersh
PostPosted: Wed Mar 09, 2011 3:34 am Up
haha fair enough!
next step is to address Lambda sensors and a possible air leak then id say
Member number: 36
leigh_boy
PostPosted: Wed Mar 09, 2011 3:40 am Up
lambda sensor , only got the 1 on mine, it reads correctly according to my dads snapon tool, i think it could be air leak or the EGR but i dont know enough about the egr really. or how to tell if its working or not.
*DEAD*206 Gti 138
Kersh
PostPosted: Wed Mar 09, 2011 3:56 am Up
to test the air leak run the engine on idle and spray wd40 (very lightly and carefuly) around the seals on the intake manifold and the seals on the throttle body. if you hear a change in engine noise that means that some has got through and that is where you have a leak Wink
Member number: 36
leigh_boy
PostPosted: Wed Mar 09, 2011 4:13 am Up
ye already done that last week, made no difference, i really think its the egr vavle but not sure on the common problems.
*DEAD*206 Gti 138
Kersh
PostPosted: Wed Mar 09, 2011 4:16 am Up
no idea mate, unplug it and see what happens. all it does is recycle gases it should be fine to unplug.
Member number: 36
PostPosted: Wed Mar 09, 2011 8:14 pm Up
Idle Control Valve (stepper)?
I know its not doing it on idle.
leigh_boy
PostPosted: Thu Mar 10, 2011 5:48 am Up
doh i snaped a bold that hold the egr down, so now i need to get the side of the engine off and drill it out or replace it looks like the side unbolts also does the water housing. I Will try pick up a ICV at the week end see if it makes any differenace but wont hold my breath.
*DEAD*206 Gti 138
Kersh
PostPosted: Thu Mar 10, 2011 5:50 am Up
did you snap it up tightening it?? as it will probably just screw out with pliers or fingers or a light drill if you did Smile
take the icv off and give it a good clean with carb cleaner, see what happens
Member number: 36
leigh_boy
PostPosted: Thu Mar 10, 2011 5:55 am Up
no undoing it, sheared off level, and its at the back of the engine, have already cleaned the valve.
*DEAD*206 Gti 138
Page 2 of 4
