Latest: jtq4u
Overall: 17141
Online Now [92]:
Visitors: 91
Today: 26015
Total: 113995125
Forums › The Car › 206 Talk › cleaning injecters
cleaning injecters
20619d
PostPosted: Fri Mar 11, 2011 2:54 pm Up
can u clean them out as been told it possible? how would i go about doing it please help
PostPosted: Fri Mar 11, 2011 3:01 pm Up
Service / exchange set or get your originals cleaned at the local injection specalist.
OR
Some injection specalists can clean them on the car as they have special equipment.
MutilateTheDead
I think redex does the job...
www.kpautomotive.co.uk...-1415.html
206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out!
PostPosted: Fri Mar 11, 2011 3:05 pm Up
send them off to specialist or use some injector cleaner, i have found wynns is best cleaner i have used.
20619d
PostPosted: Fri Mar 11, 2011 3:12 pm Up
it just my car idles lumpy for 5 mins then is fine but at low revs it little jumpy but high revs in low gears it fine. i have put new glow plugs in last winter and new oil filter and oil and new fuel filter. so think it got be injecters
PostPosted: Sat Mar 12, 2011 9:22 am Up
any diesel specialist should be able to do that for you. around 20-40quid per injectors
