Posted: Thu Mar 10, 2011 5:09 am |
leigh_boy wrote: |
no undoing it, sheared off level, and its at the back of the engine, have already cleaned the valve. |
aaah i see, lol. gutted
i dont know then to be honest with you mate, could still be an air leak, i took my entire intake manifold off and replaced all the seals on mine just to be sure. and cleaned it all out at the same time. i made a thread on it
206info.co.uk/Forums/v...ifold.html
Posted: Thu Mar 10, 2011 6:07 am |
cheers for all your help fella, il have a look at cleaning the inleet but dont think it will make any differeance, waht does taht silver hose on the inlet do and wer does the other end go?
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Thu Mar 10, 2011 6:25 am |
leigh_boy wrote: |
cheers for all your help fella, il have a look at cleaning the inleet but dont think it will make any differeance, waht does taht silver hose on the inlet do and wer does the other end go? |
no problem mate its what we are here for
its a breather for the main engine block or head i cant remember, goes into the block, youll be able to see it if you have a look
Posted: Thu Mar 10, 2011 6:33 am |
i might give that a look over incase its spil or loose or something silly
| *DEAD*206 Gti 138
Posted: Thu Mar 10, 2011 12:12 pm |
The silver hose is for the EGR/air injection system. I never quite worked out which way the air went. It basically feeds air from the inlet into the exhaust or vice versa.
Posted: Sat Mar 12, 2011 10:23 am |
GRRRRRRR!!! Bloody car, so today i have replaced the lmbda sensor, map sensor , air temp sensor and air idle controll valve still cant work it out and its getting expensive
on the gti throttle body at the back of it there are 2 hoses 1 comes from the right hand side and goes to the head and the other 1 goes off to the left and dissapears, questin is what does that one on the left do?
| *DEAD*206 Gti 138
Posted: Sat Mar 12, 2011 10:33 am |
Scan it with Peugeot Planet not a crappy Snap on
Posted: Sat Mar 12, 2011 10:36 am |
.... really don't think that will help as there are no faults listed
| *DEAD*206 Gti 138
Posted: Sat Mar 12, 2011 11:58 am |
leigh_boy wrote: |
on the gti throttle body at the back of it there are 2 hoses 1 comes from the right hand side and goes to the head and the other 1 goes off to the left and dissapears, questin is what does that one on the left do? |
I think the left one goes to the fuel tank or the charcoal filter in the inner wing.
Posted: Sat Mar 12, 2011 12:31 pm |
u might be right i managed to trace it as far as wing
| *DEAD*206 Gti 138
Posted: Sun Mar 13, 2011 5:21 am |
any other sugestions? i have noticed that the tail pipe girgles every now and again, and seems to have water spitting out, i know its not head gasket before any 1 sugests that its more like condonsation but seems to be there all the time but doesnt help with this weather.
| *DEAD*206 Gti 138
Posted: Sun Mar 13, 2011 11:09 am |
| *DEAD*206 Gti 138
Posted: Sun Mar 13, 2011 11:32 am |
if you have water comming from the exhaust constantly then water ust be getting into it somehow (thats physics lol) and the coolant is the only water in the engine... are you certain your HG isnt gone? it could be water getting into a cylinder causing one to misfire every now and again, causing that popping noise and the fluctuating revs..
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Sun Mar 13, 2011 11:40 am |
ye hg os fine, water level stays the same ans the water spits from the exhaust does not taste like coolent
| *DEAD*206 Gti 138
Posted: Sun Mar 13, 2011 11:45 am |
are you sure your running it enough to get all the water out of the exhaust? mine takes a good half hour to stop steaming in cold weather.
ive got a very similar problem atm, the revs fluctuate like that, but they also drop veeery slowly and bounce up and down when you press the brake lol. i know how fooking annoying they can be to try and sort out!
