Posted: Sat Mar 12, 2011 12:16 pm |
| Lee wrote: |
See which wire gives +12v when you close the window
I can see a few fuses blown and maybe another BSI  |
hope not, that sounds expensive
Posted: Sat Mar 12, 2011 12:17 pm |
| samreecestrange wrote: |
| MrBSI wrote: |
| Lee wrote: |
| For the drivers side, you'll need to connect it AFTER the one-touch module if you want to keep your one-touch closure function. |
Or buy a decent window closure unit & gain a passenger side one touch feature as well  |
didnt know you could do that, can u recommend any as that would be much better |
DEI 530T
US Ebay not the UK one
What alarm you using?
Posted: Sat Mar 12, 2011 12:19 pm |
the standard one
| Signature removed due to size | |
Posted: Sat Mar 12, 2011 12:22 pm |
you will also need a timer relay wired in to get the windows to close with the deadlocking system then
Orange wire needs grounding on the DEI unit to shut the windows, the deadlocking pluse isnt long enough to do this.
non plexed or multiplexed 206 as the wiring is different for the deadlocking
Posted: Sat Mar 12, 2011 12:25 pm |
ok im preplex and where do i wire the relay and could u give me a link of the relay i need pls
Posted: Sat Mar 12, 2011 12:30 pm |
| ok im preplex and where do i wire the relay and could u give me a link of the relay i need pls |
Preplex not a clue matey, shame you didnt say multiplexed
DEI 528T pulse timer relay.
Posted: Sat Mar 12, 2011 12:33 pm |
No need for the DEI 528T, an interior light relay would do the job.
Posted: Sat Mar 12, 2011 12:38 pm |
I used the DEI 528 on mine as I like my BSI unit
Maybe you could get away without it on non plexed, never tried
Posted: Sun Mar 13, 2011 10:48 am |
this is sounding much more difficult than i imagined. Where can i get an itnerior light relay.
