Latest: jackrox1992
Overall: 17186
Online Now [494]:
Visitors: 493
Today: 43964
Total: 148425649
Forums › The Car › 206 Problems › Front hub question
Front hub question
tyrone81
PostPosted: Sun Mar 13, 2011 6:22 am Up
I got myself a hub from ebay, but the guy has sent the wrong side. I'm not needing the whole assembly just the hub. Is it easy just to take the hub out and replace it? Should it just pull out? i'm thinking it will be tight.
Peugeot 206 GTI 180.
Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere.
PostPosted: Sun Mar 13, 2011 9:32 am Up
you will need a hubs puller/ sliding hammer.
and i don't think hubs are sided but i could be wrong
panason1c
PostPosted: Sun Mar 13, 2011 9:35 am Up
Not as easy as you might have hoped for..............You need access to a press to separate the hub from the carrier, in the process of pressing out the hub the wheel bearings will be destroyed, you will then need to fit new w/bearings on re-assembly to the opposite side carrier....
Edit......the actual hubs are not sided, they are the same either side.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
tyrone81
PostPosted: Sun Mar 13, 2011 10:24 am Up
Thanks mate, i'm as well leaving it alone and just get wait till i get the right side. To much hassle.
