Latest: tebas93089
Overall: 17179
Online Now [95]:
Visitors: 94
Today: 17107
Total: 138490835
Forums › The Car › 206 Problems › GTI 180 Brakes
GTI 180 Brakes
JE_180
PostPosted: Sun Mar 13, 2011 6:03 am Up
Hi guys,
yesterday my dad and myself serviced my 180. After bleeding the brakes (no air got into the braking system as he's an ex REME vehicle mechanic), we are a little confused as to why the break pedal feels spongey and has to be pressed twice as far as usual to get the breaks to work?
He mentioned on the old Army land rovers there was a valve in the braking system incase a wheel was lost which would avoid you losing fluid etc. (which had to be reset after a service by stamping on the pedal hard). Is this the same case for the peugeot?
If not and i'm talking a load of bs then could I pick peoples brains for a possible cause/solution?
If worst comes to worst and it's not an easy fix it's booked in to a garage on tuesday.
PostPosted: Sun Mar 13, 2011 6:07 am Up
GTI 180 has ABS / EBD / EBA / ESP & ASR all built in to the brake system hydraulic modulator.
It really needs bleeding with Peugeot Planet diagnostic kit.
You could try pressure bleeding it with a Gunson Easibleed kit.
spike_202
PostPosted: Sun Mar 13, 2011 6:40 am Up
The last time had my brakes bled it only cost £30 at pug so it's not to bad
**spike's project**
TEAM:+200bhp
JE_180
PostPosted: Sun Mar 13, 2011 6:41 am Up
So hopefull a garage re-bleeding them and correcting my F**k up will be the solution then lol
spike_202
PostPosted: Sun Mar 13, 2011 7:26 am Up
Lol may be they use a vacuum machine, if you don't do it right you can get air trapped in the abs pump then it is a trip to pug garage
**spike's project**
TEAM:+200bhp
