Posted: Fri Mar 18, 2011 10:19 am |
Got the angels put in, only problem is that they dip in the way instead of out the way (international lights.)
Is there anyway of fixing this??
Posted: Fri Mar 18, 2011 10:22 am |
mod it.
Your profile picture and name greatly irritates me.
| Hi Mikey
Posted: Fri Mar 18, 2011 10:27 am |
| Aar_Im_A_Pirate wrote: |
Is there anyway of fixing this?? |
what does that mean?
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Fri Mar 18, 2011 10:28 am |
Why did you fit them if you knew they were wrong?
You'll probably need beam converters ect to get them to work and be legal.. It'd of been easier and better to get the correct ones tbf
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Fri Mar 18, 2011 10:29 am |
| sillyhilly wrote: |
mod it.
Your profile picture and name greatly irritates me. |
Then dont look at them!
Could always move to another country
Posted: Fri Mar 18, 2011 10:35 am |
sillyhilly. You are not ron burgundy.
But you most likely own a horse
Posted: Fri Mar 18, 2011 10:36 am |
| Ste206 wrote: |
You'll probably need beam converters ect to get them to work and be legal.. It'd of been easier and better to get the correct ones tbf |
They were a christmas present from the gf. Also you can only tell when getting the headlights aligned.
Meh, I have the crytals to put on for mot. Quick job changes it
Posted: Fri Mar 18, 2011 10:37 am |
blind other road users if there pointing wrong way ?
Posted: Fri Mar 18, 2011 10:42 am |
i put a set of LHD lights on mine once and got flash by people on the otherside of the motorway when i was even in the slow lane! I would get them off!
Posted: Fri Mar 18, 2011 10:43 am |
Trade Rating: +45
you could buy my masked crystals off me would work a treat
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK  | |
were they made for european use, or uk use but just need aligning??
If they are for european use, I would send them back and get them swapped for uk use.
Posted: Fri Mar 18, 2011 10:48 am |
But you most likely own a horse |
Don't need a horse thank you good sir, I get a good enough ride off of Mrs Aar_Im_A_Gimp.
| Hi Mikey
Posted: Fri Mar 18, 2011 11:04 am |
Easy tiger. I came here to solve a problem and not have fisty cuffs. If you do not like it then I recommend that you grease your ass and slide on.
Edit: sorted now, was a switch at the bottom of the lights
