Latest: tbafonso
Overall: 17130
Online Now [141]:
Visitors: 140
Today: 20186
Total: 102401811
Forums › The Car › 206 Problems › Reverse Light
Reverse Light
Go to page Previous  1, 2
PostPosted: Fri Mar 18, 2011 2:03 pm Up
dugaldgunn wrote:
As far as i am aware the remote locking bit can be programmed at home
NOT without the correct diagnostic equipment it cant Wink
To code a new / replacement fob to the car it has to be hooked up to Peugeot Planet or other suitable diag kit.
The only thing an owner can do is RESYNC a previously working fob that stops working after a battery change / battery disconnection Wink
I repeat, you CANNOT code a replacement / new fob with the resync instructions, your wasting your time even attempting it Wink
dugaldgunn
PostPosted: Fri Mar 18, 2011 3:27 pm Up
Ok cheers for that. I shall make a trip to my friendly mechanic again and see if we can sort that out.
Appreciate all your help. Thank you.
Dugald
PostPosted: Fri Mar 18, 2011 3:57 pm Up
You got + 12 volts with the ignition on at the white 2 pin plug on the reverse light switch connector plug?
You then tested at the rear cluster? ? ?
Its such a simple circuit & ive never heard of a BSI failure of the reverse light circuit yet.
PostPosted: Fri Mar 18, 2011 5:23 pm Up
Don't think the reverse light even uses the BSI
Andy180+
PostPosted: Fri Mar 18, 2011 5:26 pm Up
dont think it does, hell maybe wrong but not found bsi and reverse light linked before
PostPosted: Fri Mar 18, 2011 5:28 pm Up
Just thought it was an ignition fuse > switch > bulb > earth
CBA to look up the wiring diagram Laughing
Andy180+
PostPosted: Fri Mar 18, 2011 5:31 pm Up
like it Exclamation
PostPosted: Sat Mar 19, 2011 5:27 am Up
BSI must get a signal from reverse light switch, how else would the rear wiper in reverse function work Wink
PostPosted: Sun Mar 20, 2011 7:04 am Up
Might just act like a switch input on a relay.
I'll have a look at the diagram when I get two mins Smile
PugGti180
PostPosted: Mon Jul 02, 2012 3:01 pm Up
I recently had another engine put in my 206 gti 180 and now the reverse lights don't work as well as the auto rear wipe linked when in reverse. Have tried and tested all the above mentioned but still nothing. Any ideas would be greatly appreciated.
2005 Peugeot 206 Gti 180, Silver, 38,000mls Wink
PostPosted: Mon Jul 02, 2012 3:03 pm Up
You don't need reverse lights anyway.
PugGti180
PostPosted: Mon Jul 02, 2012 3:06 pm Up
You need them for MOT do you not?
PostPosted: Mon Jul 02, 2012 3:07 pm Up
Nope. They aren't testable.
PugGti180
PostPosted: Mon Jul 02, 2012 3:08 pm Up
I see.. Ok cheers
Page 2 of 2
