Online Now [230]:
Visitors: 229
Today: 65617
Total: 138996006
Forums › The Car › 206 Problems › me again!... brake disc screws
kuushty
PostPosted: Sat Mar 19, 2011 6:20 am Up
ok so i need to get one of the screws out that holds the disc onto the front.... do i just literally heat it with a blow torch then drill it out with them reverse thread drill bits? would that work? thats what i've been told...
cheers
rob
PostPosted: Sat Mar 19, 2011 6:21 am Up
what?
would a T30 torx driver easier?
kuushty
PostPosted: Sat Mar 19, 2011 6:23 am Up
Seabook wrote:
what?
i tried that first mate, i'm not a compleet noob lol! but its just rounded off the head... they're more or less rusted in
PostPosted: Sat Mar 19, 2011 6:26 am Up
The trick with brake disc screws is:
A decent fitting torx bit & impact driver Wink
1 swift wack undo's them.
A decent make of brake disc will come with new screws anyway OR you can buy new screws from Peugeot / Citroen cheap.
kuushty
PostPosted: Sat Mar 19, 2011 6:28 am Up
got a bag of replacements off ebay for £3 .... but the head is completely f****d on it...
PostPosted: Sat Mar 19, 2011 6:29 am Up
What happens next depends on what tools you have available Wink
PostPosted: Sat Mar 19, 2011 6:31 am Up
clean it throughoutly and them hammer the torx driver into it?
that torx screw aren't that tight
kuushty
PostPosted: Sat Mar 19, 2011 6:33 am Up
well i'm off to the shop in a bit to get a new oil filter so what would i need? i only have a drill and reverse thread drill bit things available (as well as other stuff) but thats the only things i have available to get screws out... but i'm not even making a dent with the drill and reverse thread stuff
PostPosted: Sat Mar 19, 2011 6:41 am Up
Use some copper grease on the thread of the new one once you get it out.
kuushty
PostPosted: Sat Mar 19, 2011 7:02 am Up
thats the plan mate
Chris180
PostPosted: Sat Mar 19, 2011 7:05 am Up
i got some of thesefrom peugeot not long ago, about 30p each
robbing b******s Laughing
2003 aegan blue gti 180 - CatCams 804's camshafts - CatCams vernier pulley - R.S.Tuning remap
Gti 180 Project Thread
PostPosted: Sat Mar 19, 2011 7:10 am Up
I bought Brembo brake disc's so I got mine free inside the box Wink
kuushty
PostPosted: Sat Mar 19, 2011 7:16 am Up
i'm sorted with the screws i just need to get the old ones out lol
stevedude
PostPosted: Sat Mar 19, 2011 7:33 am Up
ya could just drill head off, the remove disc and get grips on the barstard
Happydays
DeadEyePaul
PostPosted: Sat Mar 19, 2011 7:46 am Up
i almost had to do this! those screws feel like they are made of TIN i chose a bigger torx screw and lightly tapped it into the problem screw and it came out to my relief
