Latest: lio94
Overall: 17181
Online Now [159]:
Visitors: 159
Today: 27625
Total: 141170082
Forums › The Car › 206 Problems › high temperature
high temperature
206racer
PostPosted: Sat Mar 19, 2011 11:15 am Up
Just changed g/f coolant and thermostat.now the temperature settles at 90 is this what it should be.When the old thermostat was in it stayed around 72.Anyone any ideas.?
51 reg
2002
1.1
hello
PostPosted: Sat Mar 19, 2011 11:51 am Up
51 reg
2002
1.1
90 sounds fine, 72 that old thermostat must have been stuck open Wink
MrrNoName
PostPosted: Sat Mar 19, 2011 11:52 am Up
MrBSI wrote:
51 reg
2002
1.1
What He Said
206racer
PostPosted: Sat Mar 19, 2011 12:03 pm Up
OK thanks for feed back.Fan kicks in about 93.
hello
MrrNoName
PostPosted: Sat Mar 19, 2011 12:07 pm Up
totally normal
206racer
PostPosted: Sat Mar 19, 2011 12:41 pm Up
I have just tested the old thermostat in boiling water and it opens before boiling and then is fully open when water is boiling then when i take it out it closes so seems to be working fine.I shall leave the new 1 in that is what the normal temperature should be.
hello
MrrNoName
PostPosted: Sat Mar 19, 2011 1:00 pm Up
my pug gets up to just above 90. i.e. 93 like you said. then the fan kicks in to take it back down to 90ish, it always sits at 90 when idling. and about 80 when driving around due to the air cooling the engine.
PostPosted: Sat Mar 19, 2011 1:36 pm Up
putting the the Theromstat in boiling water is not a good test I believe,because it's diff. when Fitted on the car,and the coolant circle makes it work as it should,so it's not accurate,and as they guys said,it may not close well,or it stays open.
on the other hand,the temp you are getting with the new thermostat is the right one,it should be on 90,and the fan kick between 93-97,so you did the right thing by changing it,when you flushed the coolant,and do this every year,so that you don't face problems with the temp,cuz Thermostat can sometime stay open,and car stay cold,OR sometimes get stuck and don't open at all,which can damage your engine and head gasket for a start Smile
206racer
PostPosted: Sat Mar 19, 2011 3:25 pm Up
We have been out in the car and the temperature rises to 90 then falls straight back down to 80 then rises again to 90 does this every so often.Could this be the temp sensor that also needs changing?
hello
PostPosted: Sat Mar 19, 2011 3:29 pm Up
If you are worried, just shove the old one back in
Mine sits about 80 odd all the time, but rises occasionally
206racer
PostPosted: Sat Mar 19, 2011 3:37 pm Up
The gauge did the same with the old thermostat in but only went to 80 then back down to 72.
hello
MrrNoName
PostPosted: Sun Mar 20, 2011 2:31 am Up
dude! seriously lol its TOTALLY FINE. yours is now doing exactly what mine does, gets up to 90, down to 80, up to 93 in traffic, fan kicks in, down to 90, or 80 if you start driving due to air cooling.
if it doesnt go above 97 it wont damage the engine due to heat. the engine likes to be nice and warm, just not too hot lol.
the new one is working fiiinnee Razz
206racer
PostPosted: Sun Mar 20, 2011 6:23 am Up
OK another update.When the car has been run and temp gets to 90 and we arrive at our destination turn engine off.Then when you turn ignition on but not to start the engine the temp gauge goes straight to 100 and then comes down to around 90.I thought it was the coolant sensor so changed it but no different.Any ideas?
hello
PostPosted: Sun Mar 20, 2011 6:24 am Up
Its called heat soak, thats normal as well.
206racer
PostPosted: Sun Mar 20, 2011 6:32 am Up
Thanks for the reply never heard of it lol.
hello
