Posted: Sat Mar 19, 2011 12:01 pm |
I've just washed my pug down, and drove it about 30minutes later, only to see the airbag indicator was flashing, i've looked at the sticky 'beginners guide to a 206', there was a new battery put in recently and the alternator is fine, im not so good with removing car parts or fiddling with them.
A friend of mine said it might be because the car could still be wet ( ?? ) does this mean my airbag wont deploy under impact?
Posted: Sat Mar 19, 2011 12:09 pm |
since its happened just after you washed the car there is a possibility that water has got into some electrics somewhere and caused the airbag fault, before doing anything give it chance to dry out fully and see if it goes off. as to whether the airbag will deploy or not when the lights on, im not sure
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Sat Mar 19, 2011 12:15 pm |
| MrrNoName wrote: |
| as to whether the airbag will deploy or not when the lights on, im not sure |
It wont
Posted: Sat Mar 19, 2011 2:58 pm |
Just been out for a spin and the light hasn't flashed, so all is fine I hope could this be a warning to get my electricals checked though ?
Posted: Sat Mar 19, 2011 3:03 pm |
i have the same problem i was coming home from work one day and moved to the side of the road cause of a bloody tractor but hit a pothole and the warning light for the airbag came on any suggestions on how to reset it ???
Posted: Sun Mar 20, 2011 2:33 am |
its a warning sign to be careful not to get water inside the engine bay when your washing the car lol. they arnt designed to have hose pipes sprayed into the radiator etc thats not natural rain haha
Posted: Sun Mar 20, 2011 5:54 am |
| MrrNoName wrote: |
its a warning sign to be careful not to get water inside the engine bay when your washing the car lol. they arnt designed to have hose pipes sprayed into the radiator etc thats not natural rain haha |
The radiator you say? whoopsies
Posted: Sun Mar 20, 2011 6:12 am |
| jdavies3 wrote: |
i have the same problem i was coming home from work one day and moved to the side of the road cause of a bloody tractor but hit a pothole and the warning light for the airbag came on any suggestions on how to reset it ??? |
Fix the problem will reset it.
How big was the pothole, non plexed 206's have been known to fire seatbelt pretensioners if the pothole is big enough
