Latest: tbafonso
Overall: 17130
Online Now [180]:
Visitors: 179
Today: 48486
Total: 103093246
Forums › The Car › 206 Problems › Boot Rattle Problem - Best Solution?
A18NHH
PostPosted: Sat Mar 19, 2011 3:48 pm Up
as title - i have an annoying boot rattle back again, i did try putting tape on the catch/latch but due to using my boot alot it's worn away again....
....just wondered if anyone had found a better/long lasting solution?
Wahoo!
Ash
PostPosted: Sat Mar 19, 2011 3:55 pm Up
Take the boot lid off.
adjust the catch a bit Wink
loosen off the torx (iirc) move it up or down a tiny bit, retighten see what happens,
PostPosted: Sat Mar 19, 2011 9:24 pm Up
+1
MrZiggerz
PostPosted: Sat Mar 19, 2011 9:26 pm Up
This and make sure you actually have both bolts for some reason, I didn't.
PostPosted: Sun Mar 20, 2011 3:11 am Up
Buy a new one! They can't be that expensive.
PostPosted: Sun Mar 20, 2011 6:30 am Up
They range from £6.73 to £17.54, choice of 4 Laughing
EmoStu
PostPosted: Sun Mar 20, 2011 7:11 am Up
this might be a stupid question, but where's the best place to get a new boot catch? I have the same problem, it's so frekin annoying
EmoStu
Peugeot 206 1.6 XSi Firedance
PostPosted: Sun Mar 20, 2011 7:48 am Up
Any Peugeot main dealer, they have these things called part's department, walk in there & speak to the person behind the desk Wink
If you know the part number you need you can even pay a visit to a Citroen main dealer if there nearer Laughing
PostPosted: Sun Mar 20, 2011 8:26 am Up
So yes it's a stupid question!
