Latest: cogeim7
Overall: 17185
Online Now [492]:
Visitors: 490
Members: 1
Today: 181531
Total: 147465597
Forums › The Car › 206 Problems › power steering wonders
brimbo
PostPosted: Sat Mar 19, 2011 4:20 pm Up
When I do a full lock either way I hear a funny whirring noise, is this normal? also when I go into any gear above 2nd, there's another whirring noise ( alternator? ) are any of these bad signs ?
threes a charm, my wheel springy things 'clunk' a hell of a lot when I turn, is it renewal time or just worn?
the pug in question is a W-reg 2000, so its had a long life.
W-reg 1.4 LX
PostPosted: Sat Mar 19, 2011 4:26 pm Up
full lock noise is normal,
Mrs_Howey
PostPosted: Sat Mar 19, 2011 4:27 pm Up
Sounds like your power steering pump, mine was doing the same.
I got a new one for £100 and now the whirring is all gone Very Happy
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
PostPosted: Sat Mar 19, 2011 9:22 pm Up
Check your power steering fluid level and top-up if necessary.
Then see if there's a slight leak anywhere.
Otherwise, what Mrs. Howey said.
MrrNoName
PostPosted: Sun Mar 20, 2011 2:26 am Up
noise on full lock is normal, its because when you are holding the wheel at full lock the pump is still operating but cant turn anymore. if you keep it at full lock but stop holding the wheel (i.e. forcing it to full) the pump stops and the noise stops Razz
