Latest: Kifi69
Overall: 17183
Online Now [373]:
Visitors: 372
Today: 169568
Total: 144009535
Forums › The Car › 206 Problems › Airbag flash
Airbag flash
brimbo
PostPosted: Sat Mar 19, 2011 12:01 pm Up
I've just washed my pug down, and drove it about 30minutes later, only to see the airbag indicator was flashing, i've looked at the sticky 'beginners guide to a 206', there was a new battery put in recently and the alternator is fine, im not so good with removing car parts or fiddling with them.
A friend of mine said it might be because the car could still be wet ( ?? ) does this mean my airbag wont deploy under impact?
W-reg 1.4 LX
MrrNoName
PostPosted: Sat Mar 19, 2011 12:09 pm Up
since its happened just after you washed the car there is a possibility that water has got into some electrics somewhere and caused the airbag fault, before doing anything give it chance to dry out fully and see if it goes off. as to whether the airbag will deploy or not when the lights on, im not sure
PostPosted: Sat Mar 19, 2011 12:15 pm Up
It wont Wink
brimbo
PostPosted: Sat Mar 19, 2011 2:58 pm Up
Just been out for a spin and the light hasn't flashed, so all is fine I hope Very Happy could this be a warning to get my electricals checked though ?
W-reg 1.4 LX
jdavies3
PostPosted: Sat Mar 19, 2011 3:03 pm Up
i have the same problem i was coming home from work one day and moved to the side of the road cause of a bloody tractor but hit a pothole Sad and the warning light for the airbag came on any suggestions on how to reset it ???
JD
New project: 206 PUG
MrrNoName
PostPosted: Sun Mar 20, 2011 2:33 am Up
its a warning sign to be careful not to get water inside the engine bay when your washing the car lol. they arnt designed to have hose pipes sprayed into the radiator etc Smile thats not natural rain haha
brimbo
PostPosted: Sun Mar 20, 2011 5:54 am Up
The radiator you say? Embarassed whoopsies Laughing
W-reg 1.4 LX
PostPosted: Sun Mar 20, 2011 6:12 am Up
Fix the problem will reset it.
How big was the pothole, non plexed 206's have been known to fire seatbelt pretensioners if the pothole is big enough Laughing
