Posted: Sat Mar 19, 2011 3:48 pm |
as title - i have an annoying boot rattle back again, i did try putting tape on the catch/latch but due to using my boot alot it's worn away again....
....just wondered if anyone had found a better/long lasting solution?
Posted: Sat Mar 19, 2011 3:55 pm |
Take the boot lid off.
adjust the catch a bit
loosen off the torx (iirc) move it up or down a tiny bit, retighten see what happens,
Posted: Sat Mar 19, 2011 9:24 pm |
NorthantsBen wrote: |
loosen off the torx (iirc) move it up or down a tiny bit, retighten see what happens, |
+1
Posted: Sat Mar 19, 2011 9:26 pm |
This and make sure you actually have both bolts for some reason, I didn't.
Posted: Sun Mar 20, 2011 3:11 am |
Buy a new one! They can't be that expensive.
Posted: Sun Mar 20, 2011 6:30 am |
Edward wrote: |
Buy a new one! They can't be that expensive. |
They range from £6.73 to £17.54, choice of 4
Posted: Sun Mar 20, 2011 7:11 am |
this might be a stupid question, but where's the best place to get a new boot catch? I have the same problem, it's so frekin annoying
| EmoStu
Peugeot 206 1.6 XSi Firedance | |
Posted: Sun Mar 20, 2011 7:48 am |
EmoStu wrote: |
this might be a stupid question, but where's the best place to get a new boot catch? I have the same problem, it's so frekin annoying |
Any Peugeot main dealer, they have these things called part's department, walk in there & speak to the person behind the desk
If you know the part number you need you can even pay a visit to a Citroen main dealer if there nearer
Posted: Sun Mar 20, 2011 8:26 am |
So yes it's a stupid question!
