Posted: Fri Mar 18, 2011 11:05 pm |
Will the h7 headlamps fit my car as mine is a h4 2000 reg hdi 206, the angels do not come with headlamp adjusters, do they normally have adjusters? Can I use my old ones?
Thank you
Posted: Sat Mar 19, 2011 12:45 am |
This has been covered many times. Do a search
| No longer a 206 owner
Astra H sxi. 1.7Cdti | |
Posted: Sat Mar 19, 2011 5:05 am |
No unless you get converters or get h7 plugs from peugeot and wire them onto your cars loom.
Edit: double check your car hasn't got the plugs tapped up in the loom.
Posted: Sat Mar 19, 2011 5:09 am |
And angels are adjustable with a flat head screwdriver, so adjusters aren't needed.
Posted: Sat Mar 19, 2011 5:16 am |
NorthantsBen wrote: |
Edit: double check your car hasn't got the plugs tapped up in the loom. |
Also needs to replace the headlamp stalk for a double optic / GTI type or get Lee to tweak his original stalk
Posted: Sun Mar 20, 2011 7:01 am |
You could just change the connector on the lamps for a H4 one, or you can buy H7 ones from Peugeot. You might have them taped up, a grey 3 pin plug.
As MrBSI said, I do modified stalks so you don't have any additional wiring.
