Posted: Sun Mar 20, 2011 4:38 pm |
I believe the 180 should have auto locking when pulling away. If this is true how do you turn it on? Thanks in advance
Posted: Sun Mar 20, 2011 4:39 pm |
Press and hold the lock button next to the hazard button, takes a good few seconds if I remember correctly
Posted: Sun Mar 20, 2011 4:40 pm |
Trade Rating: +36
Does anything happen to let you know it has worked?
Depends on how old the car is and if it's been activated on the BSI
Posted: Sun Mar 20, 2011 4:41 pm |
It'll give you a message on the mfd
macca1411 wrote: |
Depends on how old the car is and if it's been activated on the BSI |
It's a 180, so it's probably new enough to have it activated
Posted: Sun Mar 20, 2011 4:42 pm |
Car is 54 plate. How do you enable it?
Trade Rating: +45
you need to have the engine off a#but the ignition on aswell to do it, you will also here a bong type noise aswell when it is activated
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK | |
Posted: Sun Mar 20, 2011 4:43 pm |
LiamGTi180 wrote: |
Car is 54 plate. How do you enable it? |
I just said, switch the car on then press and hold the lock button on your centre console for 10 seconds or so
I've tried holding it. Any ideas?
Posted: Sun Mar 20, 2011 4:44 pm |
Did you have the key turned twice, but the ignition off?
Posted: Sun Mar 20, 2011 4:45 pm |
Ok I'll try it with engine off. I wasn't ignoring you your message hadn't come through lol. Thanks for your help everyone
Trade Rating: +45
Dabamash wrote: |
Did you have the key turned twice, but the ignition off? |
the key turned twice turns the ignition on
Posted: Sun Mar 20, 2011 4:46 pm |
meady wrote: |
Dabamash wrote: |
the key turned twice turns the ignition on |
Does it? Oh well lol. Basically, turn the key the whole way but not so that the engine comes on haha
Posted: Sun Mar 20, 2011 4:51 pm |
in the same position when you activate auto lights
| Tivoli LX 1.1
Black GTI 180
White VXR Burg | |
