Posted: Tue Mar 22, 2011 2:11 pm |
does have to be a hard hit if in the right angle. my reccomendation would be new rear quarter cut in and whilst they have it off they can sort any other issues underneath the damage.
Posted: Tue Mar 22, 2011 2:14 pm |
kyle had the same damage to his 180 when a immergrent run a red light but took the door with it too, it cost around 800 quid as they had to blend the whole side of the door in , the skin alone is around £300
Posted: Tue Mar 22, 2011 2:32 pm |
Wouldn't ask for new panel as then all the factory seals will be broken. That panel is a single skin paper thick. and totally hollow behind so wouldn't take much to do that damage. There will be no structural damage so don't worry about that. It just needs pulling out and reshaping very easy job. As for colour matching if that caint do it that shouldn't be doing the job.
Will only be a write off if your cars worth less than £500.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Tue Mar 22, 2011 3:31 pm |
I was quoted for similar damage on mine, it needed filling then a full side respray and i was going to be charged £320
Posted: Tue Mar 22, 2011 4:03 pm |
Lee wrote: |
Was it the guy with the speakers?
Maybe he was p**sed off about you mocking his car |
LOL Lee that did make me laugh..
Sorry to see about the car being hit and it's a bum that they didn't stop.
Posted: Wed Mar 23, 2011 2:14 pm |
Seabook wrote: |
300 is cheap considering the work involve to fix a rear quartor wing |
Its gonna be a simple knock it out & filler repair for those prices.
Posted: Wed Mar 23, 2011 4:19 pm |
MrBSI wrote: |
Seabook wrote: |
Its gonna be a simple knock it out & filler repair for those prices. |
That's wot you want? No a new panel as it makes a mess off all the factory seals if it was mine I would knock it out Resnais and filler it.
Posted: Fri Mar 25, 2011 2:58 pm |
nick180 wrote: |
MrBSI wrote: |
Seabook wrote: |
That's wot you want? No a new panel as it makes a mess off all the factory seals if it was mine I would knock it out Resnais and filler it. |
Depends on who does the repair.
I've had a new rear quarter fitted on a previous car & the side the body shop fitted was actually better then the other side that was factory fresh
Welds where neater & paint was a perfect match
Then again it did cost the other parties insurance nearly £1300 & this was about 14 years ago
