Online Now [147]:
Visitors: 146
Today: 9650
Total: 143207865
Forums › The Car › 206 Problems › P0300 intermitent Code Fault
Deceitful
PostPosted: Wed Mar 23, 2011 4:23 am Up
at the moment my 206 appears to have no faults, but i tend to get the emissions warning light now this is where it gets complicated. the fault is intermitent. the engine sometimes refuses to speed up and i have a rough idle. has anyone had the same problem or maybe could shed some light on this, i really dont want to pay peugeot for hours of diagnostic's as the code is unspecific Sad
spark plugs changed.
coilpack tested and not at fault.
injectors checked and not at fault.
now the only thing i can think that it could be is a MAF sensor or a Lambda sensor.
Peugeot 206 Zest 1.1 5 door
Harty
PostPosted: Wed Mar 23, 2011 4:52 am Up
my car didn't have the rough idle but when the light came on it refused to rev, like if i was at 3000 in 3rd and foot flat down the revs would start to drop for a few seconds then all power comes back, and the car would just feel underpowered every now and then. light on or off. changed the MAF sensor and seems a lot better and light hasn't showed since last friday Very Happy was told it was either the MAF sensor or the cat was blocked with 90% being MAF sensor. check for green rot sort of stuff inside the sensor and if there is either try cleaning first or just replace.
HTH
Chris
Harty
Deceitful
PostPosted: Wed Mar 23, 2011 4:55 am Up
ooo i will, its just so annoying when you get a "random misfire" code, and to be fair there isnt like a pattern to when i get the problems Sad
Harty
PostPosted: Wed Mar 23, 2011 5:50 am Up
don't think mine was a random misfire but one of the symptoms was the same and it happened every time the light was on.
Chris
Harty
PostPosted: Wed Mar 23, 2011 6:39 am Up
Unplug the MAF sensor, if the idle bounces around a bit then the sensor will be fine. You can try to clean it but with electrical contact cleaner only
Make sure you're only using Bosch spark plugs
If your MAF sensor is shafted the it will play havoc with the lambda sensors and CAT.
Deceitful
PostPosted: Wed Mar 23, 2011 3:35 pm Up
im using ngk's i doubt that would make the difference?
PostPosted: Wed Mar 23, 2011 3:37 pm Up
Yes it does, they cause the coil pack to have dicky fits
Bosch ONLY
Andy180+
PostPosted: Wed Mar 23, 2011 3:44 pm Up
Bosch ONLY
Cool french cars for you lol
pug206lx
PostPosted: Wed Mar 23, 2011 4:23 pm Up
Get a compression test done of all the cylinders before you spend anything.
Deceitful
PostPosted: Wed Mar 23, 2011 5:03 pm Up
compression test has been done all fine Smile
PostPosted: Wed Mar 23, 2011 5:05 pm Up
Change the plugs, Peugeot wouldn't have issued a service bulletin about not fitting NGK plugs if they were ok
Deceitful
PostPosted: Wed Mar 23, 2011 5:10 pm Up
oh, ive replaced them 3 times since ive had the car and no matter where ive gone they've always given me ngk? euro car parts and abm's. but surely this wouldnt cause a random misfire as the problems only just started to become more apparent, im guessing its gotta be the map or lambda =\
Deceitful
PostPosted: Thu Mar 24, 2011 9:59 am Up
just purchased some super 4's :), also isit worth getting a kn57i for 1.1 or shall i just get a kn panel?
ukskater01
PostPosted: Thu Mar 24, 2011 10:22 am Up
I would have thought a panel filter would be best as you can lose power with induction kits
Deceitful
PostPosted: Tue Mar 29, 2011 6:01 pm Up
changed to bosch super 4's admittedly slightly smoother idle probs unoticable but its going to a dealer monday hopefully its something silly!
