Latest: Stu-mill
Overall: 17131
Online Now [60]:
Visitors: 59
Today: 17455
Total: 104905049
Forums › The Car › 206 Talk › Is this normal?
Is this normal?
Go to page Previous  1, 2
leigh_boy
PostPosted: Fri Mar 11, 2011 1:38 pm Up
flush it all out , replace and same with oil and keep an eye on the levels
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
jonny_fulton03
PostPosted: Fri Mar 11, 2011 1:46 pm Up
Thats the funny thing! The cars due an oil change so the oil is on its way to black but the residue on the cap is cream coloured! And nothing on oil filler cap. Would having TOO MUCH coolant in there have an effect like this? Ill get it to a garage to get it flushed out and replaced and ill put some k-seal in the oil when i get it changed as ive got a slow oil leak. Temporary fix but will hopefully keep any catastrophies at bay for a while...:-)
20619d
PostPosted: Fri Mar 11, 2011 2:02 pm Up
i had a garage test the preasue on engine. then can tell u if it head gasket or not
PostPosted: Sun Mar 13, 2011 1:14 am Up
Looks like its got piles
But yeah ive read on here that the mayo substance is a sign of head gasket failure
Hope you get to the bottem of it
eddrj
PostPosted: Sun Mar 13, 2011 3:23 am Up
may be head gasket,
change coolant and oil and keep checking it to see if same thing happens soon after.
Old car 2000/ 206 2.0 hdi.
carlosr23
PostPosted: Thu Mar 24, 2011 8:16 am Up
Can you describe the smell of this substance? Is there any oil smell like?
Also you can try to take some oil from the engine and poor some on a cup of coolant and see if you can duplicate the color and smell
Carlos\r\nPeugeot 206 s16 2004
Gems
PostPosted: Thu Mar 24, 2011 8:25 am Up
South East Area Rep - Gems
I thought k-seal is for cooling systems only? Not for oil leaks?
www.k-seal.co.uk/k-seal.html - worked in a garage for 7 years and never heard of it being used in the oil?
jonny_fulton03
PostPosted: Thu Mar 31, 2011 10:42 pm Up
Yeah my bad Smile i mean if it's looking like the head gasket i'll put some k-seal in coolant after ive had it flushed and refilled and hopefully that should keep it alive for a while!! Joni
Page 2 of 2
