Latest: Worthy967
Overall: 17143
Online Now [541]:
Visitors: 540
Today: 119852
Total: 114855777
Forums › The Car › 206 Talk › Rear lights.
Rear lights.
egouder
PostPosted: Fri Mar 25, 2011 11:03 am Up
I searched through the forum and couldn't find what i was searching for.
Is there any how-to or quick instructions of how you remove the tail lights???
thanks
pug206lx
PostPosted: Fri Mar 25, 2011 11:05 am Up
Pull the carpet on the sides back in the boot, undo the little plastic nut behind the carpet, pull the light out and unplug it. Very very very simple.
take the interior carpet trim out, undo the wing nut, and remove the lights
Open the boot, remove the mushroom clips holding the carpet on, little round things, pull the middle part out with pliers or a screwdriver.
Then pull the carpet back, put your hand behind the light unit & there is a wing-nut, unscrew, don't drop the nut!
Then the light unit pulls out, and you remove the connector.
egouder
PostPosted: Fri Mar 25, 2011 11:07 am Up
Thanks that was extremely fast and helpful!! thanks
i thought it was harder actually.
thanks
PostPosted: Fri Mar 25, 2011 11:43 am Up
First time I did mine they were a bit tight so needed a gentle tap to move them away from the body
