Online Now [1441]:
Visitors: 1440
Today: 63888
Total: 149140566
Forums › The Car › Solved 206 Problems › RPM Sensor ( SOLVED)
Forum Index › Solved 206 Problems
Go to page 1, 2, 3, 4  Next
leigh_boy
PostPosted: Sat Mar 26, 2011 3:02 am Up
Had my car diagnosed by 2 other people 1 of them a very reptable company all for free as i do there IT for them.
but the error that keeps popping up is
Rpm sensor
neither of the companys seem to know what it is but can only guess crank or cam sensor witch both have been replaced.
I called pug they don't know they just ask to diagnose the car them selfs witch im sure it will say the same and they still wont know.
so any 1 got a clue? could it be that the sesnors i replaced 1 of them was faulty from new?
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
MrrNoName
PostPosted: Sat Mar 26, 2011 3:57 am Up
i didnt know there was an RPM sensor?
imo its most likely to be the Throttle position sensor, idle control valve, or MAP sensor, they all help to control the RPM
not 100% sure though becuase ive never heard of that fault before lol
PostPosted: Sat Mar 26, 2011 4:38 am Up
I think the crank sensor is called an RPM by Peugeot...try changing the crank sensor...only about £15 I think...
MrrNoName
PostPosted: Sat Mar 26, 2011 4:46 am Up
lol, we know the error, but what is the actual problem with the car, it might help to narrow it down
leigh_boy
PostPosted: Sat Mar 26, 2011 5:10 am Up
i went to pug and got another crank sensor for free Smile
didnt fix the problem tho,
basicaly as you drive and hold the throttle it hesitates and ou cant hold it at an rpm you have to go through the revs witch makes doing 30 , 40 , 50 , 60 , 70 hard to do if you want to stay at that speed.
*DEAD*206 Gti 138
MrrNoName
PostPosted: Sat Mar 26, 2011 5:15 am Up
hmm that is odd, doubt it would be the idle control valve then, maybe the throttle position sensors giving fluctuating readings? I would have thought that would have flagged up as a TPS code and not RPM though
leigh_boy
PostPosted: Sat Mar 26, 2011 5:19 am Up
also is this crank sensor wiring normal?
*DEAD*206 Gti 138
MrrNoName
PostPosted: Sat Mar 26, 2011 5:21 am Up
normal?
leigh_boy
PostPosted: Sat Mar 26, 2011 5:27 am Up
ye, its doensnt look right the way its like heat wrapped then 2 wires
*DEAD*206 Gti 138
PostPosted: Sat Mar 26, 2011 5:38 am Up
It's CAN its fine.
I'd guess your TPS is at fault
Davels
PostPosted: Sat Mar 26, 2011 5:42 am Up
You want to hope it's not the TPS, the cheapest i've found for a replacement is a pug dealer at 123quid, eurocarparts don't even stock them and andrew page motor factors where asking for more than that.
MrrNoName
PostPosted: Sat Mar 26, 2011 5:44 am Up
ebay?
yeh its wrapped like that to cancel out interference i think
leigh_boy
PostPosted: Sat Mar 26, 2011 6:11 am Up
sesnor that have been replaced with NEW
coolent, crank sensor, cam sensor, TPS, Idle control valve, Air Temp sensor, 1 injector, o2 Sesnor and the map sensor
center exhaust pipe, rear box, spark plugs
also checked the timing yestaday
running out of things to change
*DEAD*206 Gti 138
leigh_boy
PostPosted: Sat Mar 26, 2011 6:12 am Up
Lee wrote:
It's CAN its fine.
CAN ????
*DEAD*206 Gti 138
PostPosted: Sat Mar 26, 2011 6:23 am Up
What years the car?
Might be just the throttle thats messed up
Page 1 of 4
