Latest: tbafonso
Overall: 17130
Online Now [112]:
Visitors: 111
Today: 15196
Total: 103877368
Forums › The Car › Solved 206 Problems › RPM Sensor ( SOLVED)
PostPosted: Sat Mar 26, 2011 8:44 am Up
That wiring is normal.
This is what my plug looked like...the wiring is twisted through the shielded sleeving.
leigh_boy
PostPosted: Sat Mar 26, 2011 1:00 pm Up
Lee wrote:
What years the car?
Might be just the throttle thats messed up
1999
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
leigh_boy
PostPosted: Sat Mar 26, 2011 1:01 pm Up
dam thats clean, what is the that ontop of the thermostat housing? thats not standard isit? if it is i don't have 1 lol
*DEAD*206 Gti 138
PostPosted: Sat Mar 26, 2011 2:06 pm Up
It's a horrible coolant temp sensor for the Omex ECU. It sits in the hole that the bleed screw will be on yours. It's getting changed in a couple of weeks when my Samco hoses arrive (at last).
PostPosted: Sat Mar 26, 2011 2:26 pm Up
leigh_boy wrote:
sesnor that have been replaced with NEW
coolent, crank sensor, cam sensor, TPS, Idle control valve, Air Temp sensor, 1 injector, o2 Sesnor and the map sensor
center exhaust pipe, rear box, spark plugs
also checked the timing yestaday
running out of things to change
The car Wink
You have wasted enough money on this one so far throwing new parts at it in an attempt to fix it Rolling Eyes
leigh_boy
PostPosted: Sat Mar 26, 2011 2:28 pm Up
The car Wink
it only cost me £280 to begin with so think its still wortha bit more hassle not much tho
*DEAD*206 Gti 138
PostPosted: Sat Mar 26, 2011 2:36 pm Up
The car Wink
It sounds like your just slowly rebuilding the car from new parts & crossing your fingers one of these parts is gonna fix it.
leigh_boy
PostPosted: Sat Mar 26, 2011 2:38 pm Up
The car Wink
your about right on that 1, soon i will get an engine, and a ecu / wireing
*DEAD*206 Gti 138
leigh_boy
PostPosted: Sat Mar 26, 2011 2:44 pm Up
back to what lee was saying whats CAN ?
*DEAD*206 Gti 138
PostPosted: Sat Mar 26, 2011 2:46 pm Up
Controller Area Network
leigh_boy
PostPosted: Sat Mar 26, 2011 2:52 pm Up
and the relivance to the question??
*DEAD*206 Gti 138
PostPosted: Sat Mar 26, 2011 2:54 pm Up
Multiplexed 206's use it.
The wires twisted like that look like typical CAN twisted pair wiring.
leigh_boy
PostPosted: Sat Mar 26, 2011 3:32 pm Up
leigh_boy wrote:
Lee wrote:
What years the car?
1999
so what could be messed up about the throttle?
*DEAD*206 Gti 138
PostPosted: Sat Mar 26, 2011 4:05 pm Up
Take it to a garage with either Pug Planet, Multi Di@g or Bosch KTS or something similar.
Not the w**ky generic EOBD readers
leigh_boy
PostPosted: Sat Mar 26, 2011 4:14 pm Up
im going to book it in for ecu firmware updates next week its only £40 so will ask about diagnotics but don't want to spend loads at a dealer as i feel violated going to a dealer lol
*DEAD*206 Gti 138
Page 2 of 4
