Posted: Sat Mar 26, 2011 9:30 am |
basically i got some new h7 headlights as replacements for my h4 headlights. i bought a h4 to h7 adapter setup, including a relay and a 20amp fuse. basically my problem is when i flick on the high beam everythings alright. but when i flick them off it blows fuses 31 and 32 which are for low beam... any ideas people? need help asap please
| Smoothed & Clean or Nothing at all | |
Posted: Sat Mar 26, 2011 10:02 am |
Sounds like the adapter is wired up wrong.
Remove the relay in it, and see if the fuses blow still
Posted: Sat Mar 26, 2011 10:49 am |
Removed and the fuses didn't blow... Leave relay out??
Posted: Sat Mar 26, 2011 11:00 am |
It means you've wired the relay up wrong
Posted: Sat Mar 26, 2011 1:03 pm |
As it came mate, do I really need it??
Posted: Sat Mar 26, 2011 1:09 pm |
If you want the dipped beam to stay on when the main beam is, then yes
Posted: Sat Mar 26, 2011 1:35 pm |
Nah tbh as long as it works I'm happy
Posted: Sat Mar 26, 2011 1:37 pm |
| robdob wrote: |
Nah tbh as long as it works I'm happy  |
MOT failure if its not working
You dont need adaptors with a relay to go from H4 to H7 on a 206 anymore, that problem is solved much easier
Posted: Sat Mar 26, 2011 2:09 pm |
Mot is next year now so not fussed
Posted: Sat Mar 26, 2011 2:19 pm |
| robdob wrote: |
Mot is next year now so not fussed  |
Until you drive down an unlit country road & go for main beam
total waste of timing fitting crystals if you cant be bothered to wire them up correctly
Posted: Sat Mar 26, 2011 4:07 pm |
welli tried wiring up the relay differently and no luck
Posted: Sat Mar 26, 2011 4:56 pm |
can you not just fit the new light stalk?
Posted: Sat Mar 26, 2011 5:01 pm |
| Seabook wrote: |
| can you not just fit the new light stalk? |
i agree
just leave the relay out and do this if you still having trouble.
Posted: Sat Mar 26, 2011 5:12 pm |
where cam i get one cheap?? and how would i fit it??
Posted: Sat Mar 26, 2011 5:37 pm |
