Latest: Beduff1977
Overall: 17134
Online Now [2484]:
Visitors: 2483
Today: 67123
Total: 109921931
Forums › The Car › 206 Talk › A few part number requests please :)
Rob2859
PostPosted: Sat Mar 26, 2011 6:17 pm Up
Plastic door trim clips
SP grill clips
Door card clips
Upper grill clips (The plack plastic one)
Badge grill clips (The ones that attach it to the wings)
Wheel bolts (for 306 harriers; 185 width and I believe flat head not tapered)
Locking nuts as well
Prices for the SP grill clips and bolts if known as well please I am assuming the rest are a few pence each.
Thankyou in advance Smile
cartoonhead
PostPosted: Sat Mar 26, 2011 6:20 pm Up
heres a eBay listing for SP Grill Clips
Rob2859
PostPosted: Sat Mar 26, 2011 7:01 pm Up
Is that VAC 882 I see the part number? Very Happy
Davels
PostPosted: Sat Mar 26, 2011 7:18 pm Up
Pictures have been nicked from another post on here but hopefully these are some of the bits you asked for
Black mushroom clips holding the upper black grill are 6997 T2 £0.44
The little clips that hold the middle bit with the badge in the centre that clip in to each wing are 6995 X3 but can't remember the price, maybe around 23p or something.
And fyi the black grill that your are getting the black mushroom clips for is only about 18 quid from the dealer new if yours is a little shabby
part no is 7804 H5
Double check all the part no's tho, and if your unsure give you reg at the parts desk and they will print off a breakdown of all the standard front end and all the different parts
Rob2859
PostPosted: Sat Mar 26, 2011 7:33 pm Up
cheers mate. Any advice on how to get the grill off from the wing? I snapped mine last time. The stupid garage who fixed my car seem to have put some strange clips on the black grill that look like they only go on once and are a pain in the a**e to get off
PostPosted: Sun Mar 27, 2011 2:47 am Up
Did it have black plastic clips?
They always snap, Peugeot replaced them with stronger clips that are white, you just yank them & they never break Wink
Davels
PostPosted: Sun Mar 27, 2011 11:07 am Up
The clips can be a pain, now i have the new white ones i have more confidence to just yank it off, try to get your fingers in the gap and prise it off, people say never use a flat blade screwdriver, but the first time i took it off i wrapped it in a microfibre cloth to avoid damaging the wing or grill. Once I got the blade behind i didn't lever it off, i held the driver as low down as poss and pulled the whole thing towards me.
But i take no responsibility for any damage your do as a result, if you do this Wink just go easy
Rob2859
PostPosted: Sun Mar 27, 2011 6:01 pm Up
The black grill is new, it doesn't have mushroom clips on it they are different. Unless to garage though it would be a good idea to cut the heads off before they put them in. As for the bit that goes to the wing it had white ones on before. I ended up snapping the bits that actually hold the clips to the grill. As well as the grill itself just under the headlight. Embarassed
cheers for those numbers.
