Latest: Kifi69
Overall: 17183
Online Now [438]:
Visitors: 437
Today: 134162
Total: 144593813
Forums › The Car › 206 Talk › Brake Painting Question
Forum Index › 206 Talk
j4m1e
PostPosted: Tue Mar 29, 2011 3:26 am Up
Hi,
I have read all the posts about painting the Brake disc's covers and drums but i was wondering... i have a tin of hammerite paint can i use that on the drums and disc covers ? or do i need to buy another type of paint ?
I have read post on the tinternet too and they all seem to think it works fine if not better then other paints
cheers
Jamie
Jamie VW Polo
thompson69
PostPosted: Tue Mar 29, 2011 3:36 am Up
Thats what I always use n it works fine bud
1999 1.6 v8 ripspeed front door speckers, jbl back door speskers, vibe slick 6x9s. gti steering wheel, momo gear knob, debadged, after market bonnet vents, m3 mirrors with leds and info sticker
Danw_VVT
PostPosted: Tue Mar 29, 2011 3:40 am Up
hammerite is fine to use. just mask the discs etc up well if your not taking the calipers etc off .
j4m1e
PostPosted: Tue Mar 29, 2011 3:44 am Up
excellent ! time to get painting Wink i think im going to do this in the bank holiday after my holiday to benidorm Wink lol so i'll post up some pix on the finishede product Very Happy cheers
Jamie VW Polo
kingdom200
PostPosted: Tue Mar 29, 2011 3:57 am Up
yeh what Dan said.....i ended up painting pipes and clips haha
PUG1OFF Cat Cams/ ECU project
j4m1e
PostPosted: Tue Mar 29, 2011 4:01 am Up
thats a point what pipes can you paint using hammerite ?
Jamie VW Polo
sillyhilly
PostPosted: Tue Mar 29, 2011 4:04 am Up
I did mine 2.5 years ago when I still had alloys on. WHEN the car's clean, the finish is still brilliant.
Hammerite ftw.
Hi Mikey Smile
Didz
i wouldnt paint any pipes mate, certainly not rubber ones like brake hoses etc, they would probably flake aswell.
Life's for living....
j4m1e
PostPosted: Tue Mar 29, 2011 4:13 am Up
ok one more question how do i remove the calipers ? *or is there a post on here any ones knows of ? * or is it just easier just leave them on ?
Cheers
Jamie VW Polo
sillyhilly
PostPosted: Tue Mar 29, 2011 4:14 am Up
I didn't even take them off tbh with you.
Hi Mikey Smile
DeadEyePaul
PostPosted: Tue Mar 29, 2011 4:18 am Up
www.206info.co.uk/Foru...=1797.html
Same for all models, mine however had a oversized torx bolt (t55) holding calipers onto the hub
captian
PostPosted: Tue Mar 29, 2011 4:44 am Up
here is a look at doing it:
www.fueltopia.co.uk/pr...per-refurb
www.fueltopia.co.uk/group/206info
j4m1e
PostPosted: Tue Mar 29, 2011 5:03 am Up
this is a bit of a neewb Question ... but whats the best way to do this .... i.e can i just jack one side of the car up at a time and do one wheel or using jack/axle stands ... if using the secound option where do the stands go ?
Jamie VW Polo
Danw_VVT
PostPosted: Tue Mar 29, 2011 5:13 am Up
check your manual for jack points
Didz
this can be done 1 at a time, tip though. turn the wheesl to the right. give you better access to the bolts and rear of caliper.
