Latest: Kifi69
Overall: 17183
Online Now [428]:
Visitors: 427
Today: 155345
Total: 144614974
Forums › The Car › 206 Talk › rear wheel spacers?
rear wheel spacers?
Forum Index › 206 Talk
benbmx08
PostPosted: Tue Mar 29, 2011 1:37 pm Up
anyone got or seen wheel spacers on the rear of a GTi? its just a thought as i have SP arches and wheels look like they could do with comming out 10mm.
GRAND TOURISME NO. 1199
PostPosted: Tue Mar 29, 2011 1:39 pm Up
just get any hubscentric wheel spacer will do.
spacer are not specific for front or rear
Uz
PostPosted: Tue Mar 29, 2011 1:43 pm Up
Running 20mm hubcentric spacers on my XSi which has the same beam as the GTi purely because of the wheels wanting to be flush with the arch and also due to the stance.
EuroPeugeot
PostPosted: Tue Mar 29, 2011 1:44 pm Up
I know that with 16" Nimrods and 20mm spacers, the tyre WILL scrub. Obviously depending how low your car is.
So I'd suggest 15mm or less. And as above hubcentric!
benbmx08
PostPosted: Tue Mar 29, 2011 1:51 pm Up
yea there's not alot of room in there haha going to have to do some investigation. maybe have the lip on the inside of the arch rolled at the bodyshop through work. 15mm front and rear then i supose. ohh heres a link to a pic i1046.photobucket.com/...inroad.jpg
Uz
PostPosted: Tue Mar 29, 2011 1:58 pm Up
Running 20mm with 406 Nimrods so the wheels are sitting at ET-2 all round and I've not even got an inch of rubbing and I've got the car lowered temporarily at 50mm. But I'm running 4o profile tyres.
PostPosted: Tue Mar 29, 2011 2:03 pm Up
any people at the back?
Uz
PostPosted: Tue Mar 29, 2011 2:04 pm Up
Yep. 2 sisters and my little bro and his booster chair + my amp and sub box in the boot.
EuroPeugeot
PostPosted: Tue Mar 29, 2011 2:06 pm Up
I said depending how low your car is lowered and I did not state how low mine was.
Also I'm sure the ET and/or tyre width is different between the 206 16" nimrod to the 406 16" nimrod.
Laughing
you sure yours is a 206?
even standard 206 might rub at that situation lol
PostPosted: Tue Mar 29, 2011 2:07 pm Up
406 is 15, while 206 is 28
both are 6j i think...
benbmx08
PostPosted: Tue Mar 29, 2011 2:08 pm Up
ill add that i have 205/40/16 tyres on the back
Uz
PostPosted: Tue Mar 29, 2011 2:11 pm Up
Laughing
Well last time it was. Im running 195/40 conti tyres on mine so I've got tiny side walls but had a single problem, there's still plenty off gap between the lip of the arch even with the spacers and my tyres and I've got SP arches fitted to it.
Width of the Nimrods are 6.5J and the offset if ET18 on the 16" 406 variants.
