Latest: KevinRC
Overall: 17137
Online Now [206]:
Visitors: 205
Today: 103597
Total: 111138047
Forums › The Car › 206 Problems › Problems After BSI Replacement
Punky
PostPosted: Tue Mar 29, 2011 9:56 am Up
I've just had my BSI unit replaced as it was faulty and the windscreen wipers had stopped working.
Since it's been replaced I've noticed a couple of things aren't working right and wondered how I go about restting them or if they are correct.
1 - The oil temp gauge no longer works and I've been told that it's a fault with the sensor, but I'm sure it worked before the BSI was replaced.
2 - When you have the headlights on and turn the main beam on, the headlights go off. The car has seperate bulds for the two.
3 - I was getting an auto lighting fault when you turned the car on, this wasn't there before. The guy who swapped the BSI has disabled the sensor so I no longer get the error, but it also means the auto rain sensor doesn't work either.
Anyone any ideas on what the faults could be or if it's just a setting in the BSI then what setting.
I've got a 53 plate 206 HDi.
Cheers for any help.
PostPosted: Tue Mar 29, 2011 11:50 am Up
2nd hand unit I take it?
Sounds like a right bodge up Rolling Eyes
Punky
PostPosted: Tue Mar 29, 2011 3:34 pm Up
Yeah I think it was a second hand one. Guy said he had years experience with them. Seemed to know what he was doing, but as you probed a little deeper into some of the things he said I'm not too sure.
PostPosted: Tue Mar 29, 2011 4:36 pm Up
The settings need activating in the BSI again.
sounds like he hasn't set it up right
Punky
PostPosted: Wed Mar 30, 2011 3:02 am Up
Don't suppose you know anyone good around the Cheshire area who'd go through the settings?
PostPosted: Wed Mar 30, 2011 3:57 am Up
Probably have to go to Peugeot unless there's a auto-electrician that can do it.
I'd take it back to the guy.
It would cost about £65 for me to come and do it.
PostPosted: Wed Mar 30, 2011 12:27 pm Up
If he knew what he was doing you wouldnt have joined up on here to ask this question Wink
Mileage display ok?
Factory radio still working ok?
Davels
PostPosted: Wed Mar 30, 2011 12:55 pm Up
Lee has been offering advice on my ECU problems and I can say this is a chap who knows his stuff, (not that I do but like you say the more speak to someone the more you get an idea of what they are about) If you want it done properly I would seriously think about taking him up on his offer. I know money may be tight though after already paying for the replacement unit.
