Online Now [601]:
Visitors: 600
Today: 138556
Total: 145617534
Forums › The Car › 206 Problems › Fog lights not working
Rob2859
PostPosted: Wed Mar 30, 2011 7:29 am Up
Both don't work. Bulbs are fine, fuse is fine. any ideas?
Oh and the dash still shows the symbol so the bsi should be getting the signal.
PostPosted: Wed Mar 30, 2011 7:30 am Up
Wiring to the bulb, or bulb holder
Icetto
PostPosted: Wed Mar 30, 2011 7:40 am Up
I got the same problem Sad
Rob2859
PostPosted: Wed Mar 30, 2011 7:42 am Up
The reason they may have gone is because When I changed them I left a platic film over one of the bulbs. Although I would have though it would only cause an issue with that particular one?
Any particular part of the wiring? How easily can I get to it as I don't know where the wires go to.
How could it be the holder?
PostPosted: Wed Mar 30, 2011 8:56 am Up
Test for +12volts going to the bulb, if there is, then you've got a earthing problem.
If there isn't, then there's a break in the wiring from the bsi to the fog somewhere.
If the light is coming on, on the dash, then its a dodgy wire somewhere.
Don't they work since you changed the bulbs?
You sure you fitted them right? As the earth wire connects to the bulb holder which connects to the 'frame' on a h1 bulb
Rob2859
PostPosted: Wed Mar 30, 2011 9:08 am Up
thanks for the :info:
No sorry I changed them for some whiter bulbs and they worked for a few weeks. Replaced them since then.
I fitted them right. However I am pretty sure last time I changed then when they were working the bulbs were on without them being in the holder :s
I will check for voltage if I can find my tester Very Happy
PostPosted: Wed Mar 30, 2011 9:14 am Up
The 'spade' on the bottom is the positive
The semi circle thing that sticks out, is the earth
Rob2859
PostPosted: Wed Mar 30, 2011 9:25 am Up
maybe I was touching it on something then that caused it to earth. Although I have tried them in the holders so I think I best check for power.
Bit off topic but seen as I have your attention lee; How can my rear wiper still work when I pulled the fuse? I am Sure its the right one as I checked my handbook for the fuse number.
PostPosted: Wed Mar 30, 2011 9:31 am Up
Pulled the wrong fuse then.
When I took the fuse out of Matt's it didn't work at all
Fuse 11, 15amp, its a mini fuse
Rob2859
PostPosted: Wed Mar 30, 2011 9:46 am Up
yep thats the fuse I took out certain of it :s
PostPosted: Wed Mar 30, 2011 9:52 am Up
While you've got the multimeter out, probe the rear wiper.
Should have 3 wires, a +12, a stop command wire coming from the other side of the motor and a earth.
See if voltage is still going to pin 2 [stop command] when you turn the wiper on. This wire comes from the BSI
Rob2859
PostPosted: Wed Mar 30, 2011 10:55 am Up
cheers. will do. Just tried the fuser again. Its also a 10amp for some reason. Put the bulbs in again, one worked then after i put the other in they both stopped. Going to check the fuse for that too and take the other bulb out again. Your helpfulness amazes me lee Very Happy
