Posted: Fri Apr 01, 2011 11:53 am |
hi
i am new to this forum and driving (only passed a few weeks back). i am starting to regret buying this car. when i first got the car left indicator at rear needed a new bulb. i replaced it and they seemed fine. now the indicators stay on even if the engines off. i have checked fuses and all bulbs they seem fine. i have been advised by friends to get a new fuse box for the driver side and also that its the bsi. i have been told to replace the relays. i am very confused as to what i am supposed to do with it. the other lights are fine. although the radio now works suddenly half way down the road and when you turn the key once the lights should come with the radio before you turn the key again for the engine which it doesnt anymore. please explain in lymans terms how i sort my pug out. i have only had a few weeks and really enjoy my freedom.
cheers for any brainwaves xx
Posted: Fri Apr 01, 2011 11:55 am |
Take the stalk/Com off and see if the indicators go off
Posted: Fri Apr 01, 2011 12:15 pm |
ok how do i do that??
Posted: Fri Apr 01, 2011 12:48 pm |
Year of car?
Posted: Fri Apr 01, 2011 12:51 pm |
Welcome to the site. You're finding the joys of Peugeot electrics. Is it all your indicators or just one side?
Posted: Fri Apr 01, 2011 1:34 pm |
its all the indicators. 1999. but so far everyone seems to think its a electrical rather than a mechanical issue. my head hurts thinking about this car.
Posted: Fri Apr 01, 2011 2:30 pm |
Posted: Sat Apr 02, 2011 7:27 am |
hi
i followed the instructions and the stalk seems fine the lights are still too.
cheers
Posted: Sat Apr 02, 2011 10:21 am |
So the indicators still stay on with the stalk removed?
I'd go with the relay is stuck on, its inside the BSI
Posted: Sat Apr 02, 2011 10:23 am |
Might be replaceable if your handy with a soldering iron.
Might be a job for BBA
Might just be a replacement BSI
Posted: Sat Apr 02, 2011 10:26 am |
Try unplugging the hazard switch as well.
But as the car is 12 years old, wouldn't surprise me if the relay has packed in.
Posted: Sat Apr 02, 2011 11:26 am |
ok, so how do i fix this?? and where do i find the relay and bsi? how will i know which relay does which?
am still waiting on me haynes manual in the post. unfortunately who i bought the car off didnt have a manual or even a lot of history.
cars these days confuse me their just tooo complex. i prefer the oldies!!
Posted: Sat Apr 02, 2011 11:39 am |
maxine877 wrote: |
cars these days confuse me their just tooo complex. i prefer the oldies!! |
You have a simple non plexed 206, you would be even more confused if it was multiplexed
Posted: Sat Apr 02, 2011 11:40 am |
You've only been passed a few weeks, how many cars can you have had
The BSI is in the drivers fusebox, the bottom row of fuses are directly in the BSI
If you don't want to crack up the BSI, and do soldering on the circuit board, you can always rewire the indicators
Removal of the BSI from the car
- Remove the fuse box cover
- Remove the protective cover from the underside of the fusebox
- Unscrew the BSI Torx screw (Torx20) and push the retaining clip at the lower part of the fusebox (see below)
- Now push the BSI down, and pull it towards you
- Flip the BSI upside down:
- Remove the Grey (GRIS), Blue (BLEU) and Yellow (JAUNE) connector:
- and the Black (NOIR) and Green (VERT) connector:
- Open the wire binder, and remove the wires from the binder
- You should now have the BSI:
Removal of the relays from the BSI
- Open the BSI by pushing all retaining clip on the sides and taking the two parts apart:
NOTE: To remove the PCB from the cover, all connectors on the PCB have to be desoldered.
Because this is a lot of work (if not impossible) you should try to avoid it (it's not needed;).
If you're not able to remove or place the relays, you can always cut a piece of plastic out of
the cover right above the relays.
- Desolder the 5 leads of the two relays (you need the solder iron to be about 400°C)
- Pin 3 (indicated with green arrows) is probably the hardest pin to desolder. So desolder the other pins,
then heat pin 3 as long as needed to pull the relay from the board.
- You should now have the two relays removed from the PCB:
The new relay
The relay is the FBR51ND10-N (51ND10-N) from Fujitsu (datasheet 1Mb)
In Europe it is available through Conrad Electronic, partnumber 505102-89. (Actually the FBR51ND12-W1)
If you can't find this relay in your country, you can also use the G8QN-1C4-DC12 from Omron as a replacement (datasheet 500kb).
This relay is amongst others available through Digi-Key, partnumber Z2696-ND.
(NOTE: I haven't tried this relay myself, I choosed it based on the datasheets. So use it at your own risk.)
Placing the new relays
OK, this is quite a fiddly work, since you can't just put the relay on the PCB from the top, because of the cover.
But I managed to do it, you just need some patience.
As I said before, if it doesn't work for you, just cut a piece from the cover.
OK, now the relays are placed, you can place the BSI back in your car.
Just do the reverse of removing the BSI.
Posted: Sat Apr 02, 2011 1:17 pm |
right i think am gonna have to do this monday when kids are at school and the shops are open.
wish me luck
