Latest: lio94
Overall: 17181
Online Now [393]:
Visitors: 393
Today: 31195
Total: 141341940
Forums › The Car › Solved 206 Problems › Front Fog Lights....NO Joyyy :((**SOLVED**
Go to page 1, 2, 3, 4  Next
PostPosted: Sat Apr 02, 2011 12:45 pm Up
Hi All,
Today I fitted a New front Bumper with Fog lights,my car didn't had ones before,so I fitted them today,and connected the plugs which where hooked behind the headlights,and I put a (15) fuse in the fuse box which in located in the engine bay in number (6),then I used the PP2000 to activate them,which I did,and it gave me the fog light light on the speedo,but the foglight didn't went on :(,so I wanna know what goes wrong,even though I tested the fog lights bulbs before I fit them,and they worked fine,so please help me.
Tim
PostPosted: Sat Apr 02, 2011 12:47 pm Up
Test to see if the +12v is reaching the fogs, if it is. Then is a earthing problem.
PostPosted: Sat Apr 02, 2011 12:54 pm Up
Thank you so much for your fast reply :),will do that in the morning,because it's dark outside,it's 10:00 PM now :(,and see how it goes,I will keep you posted,thanx Smile
So if it was an earthign problem,should I check the earthing points located under the headlights on (L+R)??
PostPosted: Sat Apr 02, 2011 12:55 pm Up
Yeah just get the earthing points, or run new earth wires.
The earths on the fogs are pretty s**te tbh
Bailey
PostPosted: Sat Apr 02, 2011 12:58 pm Up
Think this has happened to mine. My car had working fogs before but now changed the front bumper and one side is now not working! Pain in the ass.
PostPosted: Sat Apr 02, 2011 1:23 pm Up
Well you didn't mention the other side of the problem,which is "What if there is no +12v feed reaching the fogs??is there is a relay that I need to check,or they don't need relay??
PostPosted: Sun Apr 03, 2011 4:22 am Up
well I took the fogs plugs out,and I check by the voltmeter,but there is no +12v,it shows zero :(,so what can I do next??
mattievrs
PostPosted: Sun Apr 03, 2011 4:26 am Up
you say you used the loom from behind the headlights? Would this not be the other headlight loom that is in most 206s for either h4/h7 connectors? And not for fogs?
NO LONGER ACTIVE ON THE FORUM
PostPosted: Sun Apr 03, 2011 4:29 am Up
2006 should have crystals as standard, so the h7 will be in use.
So the spare one should be the 2 pin, grey connector for the fogs.
Test to see if power is reaching the fuse like I said.
Could always check the amps when you turn the fogs on, to see if it changes.
Matt
PostPosted: Sun Apr 03, 2011 5:15 am Up
Trade Rating: +32
This
PostPosted: Sun Apr 03, 2011 5:27 am Up
But the looms behind the headlights couldnt reach down to the fogs could they?
PostPosted: Sun Apr 03, 2011 8:12 am Up
As Lee said,I have H7 headlights,and I have the Grey plugs ready in the loom for foglights,and it's 2 Pin and fitted 100% on the fogs.
PostPosted: Sun Apr 03, 2011 8:14 am Up
They reached down the fogs very well,it's made for that purpose,I will post pics soon
PostPosted: Sun Apr 03, 2011 8:27 am Up
no i mean the headlight looms could surely not reach to the fogs?? well mine dont!
PostPosted: Sun Apr 03, 2011 8:36 am Up
Headlight looms are plugged into the headlamps Laughing
Page 1 of 4
